Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
0 Members and 61 Guests are viewing this topic.
adrouk
Tesla radiant energy easy diy cosmic energy lights 240v
https://youtu.be/srwU9d5bsHs
Coupled with Tesla pancake coils diy sand heater https://youtu.be/LRFI0V-2DlA instead of solar system and you don't need to pay any gas/electric for heating your home.
If indeed we have here so many assets with skills and resources should be easy to see in less than 1 month few micro production lines pumping the market with different purposes and output.
Like, replace you heater exchange in your existing heating system with something derived from the above. Make a secondary unit to provide power for your domestic appliances etc.
All in the open ! :) And cheap to replicate without the need for expensive instruments, just make it and use it as you please.
I would strongly suggest downloading or recording as soon as you can, as if it get popularity it might disappear.
Just don't use keywords unaltered, always specify solar or whatever for avoiding unwanted things happening.
pauldude000
I wish people would quit making out the term "radiant energy" as if it were something lost, magical, or mystical. Tesla invented the term to explain phenomena he was seeing, specifically having to do with electrical fields. The term was used all over the place, everything from "radiant tubes" that used the brush effect from high current low voltage D'Arsonval style high frequency coils to the purple corona discharge of Tesla or Oudin style high frequency devices.
But then again, I shouldn't be surprised as most people don't know the difference between coil types. If the secondary is connected to ground, hint, it is not a Tesla coil. Most coils called a Tesla coil are in fact Oudin style high frequency coils. Yes, Tesla himself used all three types in his research, don't be surprised at that either. The highest voltages combined with the lowest currents are derived from Tesla style HF coils. Lowest voltage highest current are from D'Arsonval auto-transformer pancake style HF coils, mid-range on both comes from Oudin style HF coils.
Tesla's 685,957 radiant energy patent concerns the natural electric field of the earth. How is that radiant energy? Tesla knew it was caused by energy RADIATED FROM THE SUN. The earth acts like a giant capacitor in that respect, with the ball of dirt acting as one plate, and the ionosphere acting as the other. Lightning is a byproduct of voltages exceeding the breakdown voltage of the dielectric (air). The charge difference in the dielectric between the ionosphere and the ground is between 100 and 300 volts per meter.
That patent tells a basic structure using capacitance and a spark gap (figure one) between two electrically isolated plates to harness that natural energy, and how to use it in a few ways. the last two figures is that patent show you that it applies to directed radiant energy (parabolic dish as the source) or from a radiant energy tube, common at the time for "electrical medicine."  Nothing in that patent is even mysterious, let alone mystical -- in any sense. Engineers at the time knew exactly what the patent referenced, as it was a novel way of harnessing something thought to be worthless and unusable by science.
For those interested, figure 4 shows how to use a mechanically turned commutator (instead of a spark gap) in series with a primary coil to run a Tesla coil. Understand that an ordinary spark gap would work, not tht difficult to understand.
For those familiar with original HF Tesla coil circuit design, the stuff in figure 1 should stick out like a sore thumb. Spark gap across a capacitor, collector plate in the air, grounding plate buried in the soil. The two plates replace the high voltage source usually powering the tesla coil.
Understand that a D'Arsonval coil can be used to step down the voltage of such a device, though it would be HF at that point.
The Earth's electric field itself is not AC, but is in fact high voltage DC. It is a static field, like exists in any capacitor.  He put a capacitor inside an active capacitor to tap into some of the stored field energy.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
onepower
Cloxxki
QuoteGreat use of AI, and for those skeptical, a response that seems worth fact-checking.
Producing O2 gas as a product, huh? Well how 'bout that!
A bit like Bedini circuits degreding the battery chemisty where the battery was supposed to be the constant factor. Consuming the engine, very VERY inspired of you to come up with and then ask Chat GPT about.
I tend to follow the best interpretation of Occam's razor. Which is, "the answer which relies on the fewest assumptions is probably the right one". Many say, "the simplest answer is the right one" but this is a fallacy. Logically, an answer can be simple but still be wrong. When we say answer we mean a fact and all facts rely on the fewest false assumptions.
For example, many critics claim a FE device must violate the Conservation of Energy. However if the COE cannot be violated then how could a FE device violate it?. It's clearly a false statement because it directly contradicts itself and yet we hear it all the time. Which begs the question, if a FE device cannot violate the COE then where does the energy come from?.
AC
forest
adrouk
Quote from: pauldude000 on August 20, 2023, 06:00:42 PM
Paul Andrulis
I didn't say anywhere that it might be something magic, quite the opposite !
Although I enjoy to see another explanation of the phenomena and nicely statement about being surrounded by energy.
Those videos just prove that we don't need an phd in nano molecular or astronomy to make a simple device using few wires, transistor and capacitors to get our homes powered and warmed up. Yet it is a very simple and inexpensive device easy to replicate and should be done in schools as many adults are just blinded by mainstream "science"
Yet I can see on forum people struggling to replicate Don Smith, Kapanadze and they just don't think that all they need is their wire lengths needs to match a fraction of wave length for frequency and their air core transformers produce standing waves being shorted and amplified waves create a huge energy ready for collection, they can't understand that if you don't use the gradient potential you need a battery to create that needed disturbance, yet they fall for silly trap of fe deniers to loop to prove whatever. Also designing their devices they don't look to match the desired load with their system but still expect to see wonders in the sky.
Yet, it seems very difficult to see that using electricity is just shorting + with - in any devices you can find on shops, and they are utterly inefficient on how they have been designed for not being harmonic with the environment and most of them are just an fancy heating element sometimes with a screen, speaker and mic attached.
In Nikola Tesla and Arie Melis deGeus inventions we can see that HV at hf resistance of copper is almost nothing and electricity is always accompanied by magnetism, yet they still search for superconductors at room temperature as a new method for antigravity when we know the tech already exist and being used.
Now if my rant is excused by your grace, I can't see why we don't have anyone replicating this simplified schoolgirl project to prove or disprove the utility of another Tesla's inventions along with many other that we are using even without noticing.
And, please don't get me wrong, but I believe that if we start to use this energy we may witness less devastating storms and hurricanes around the globe according with the level of modern lifestyle  for at least 1/2 of inhabitants on this planet.
