Implosion Motor "tornado water (hydraulic) spout"
Started by TommeyLReed, April 29, 2021, 06:20:53 PM
tonygiang
Hi TommeyLReed !
The stator can add thrust like this:
TommeyLReed
Hi all,
I had to remove most of the build videos due to my contract and a partner, But I still have two last videos up and looking to show the new setup very soon.
I have a 50kw generator on standby and will be using the implosion motor to power it.
Some data of the build has become private.
Thank you.
https://www.youtube.com/watch?v=JPlY12K5Kh4&t=68s
https://www.youtube.com/watch?v=G8qpsFH4RME&t=8s
Tommey Reed
seychelles
TOM SUPER GREAT WORK. MY TWO BOBS WORTH. WHY DON'T YOU PUT FIXED IMPELLERS AS
ATTACHED TO INCREASE THE REV AND TORQUE.
seychelles
NOT THE TURBINE BUT JUST THE BUCKETS. YOU FIX THEM CENTER OUTSIDE OF THE ROTATING JETS.
TommeyLReed
Hello Seychelles,
Yes I'm fully aware of the technical design and it also defuse the thrust vector.
It will increase power output, but decrease as the it speeds up.
I'm waiting on a few more parts and modifying the design with a new gear pump to match the 10hp@3600 motor.
In fact all the calculation should show total input of power vanish.
The test was kind of a success, but the pump was a over kill. The total input should have been at 70% efficiency ((70psi@13gpm)/.75)= 1300/1714=0.75hp or 559 watts.
With centrifugal force 559w-300w = 259w
Thank you for your opinion.
