Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
kajunbee
I can see how that might score me some brownie points Ramset. I also think that's a great way to describe it. If that doesn't snap one into reality then nothing will.
You are right ,Chet ! ( You hidden ' Modernist')
Even Jesus,it is written( I think so),only multiplied ordinary fish and vine !
Probably he had a contract with the cement block industry or the components from cement is for multiplying too dry !?
Who knowes it,we have to work faster for the Jesus-time-back-machine,for asking and confirmation  !
There are not more important question/s than these/this !
Sincere,schoenes Wochenende
OCWL
nix85
Lanca, nothing about that heat collector is above COP 1 let alone 10, in English, Portuguese, German or Mandarin.
If you want COP 80 heater..
https://infinitysav.com/centrifugalboiler/
You are entertaining,are not You ?
What is for You the problem with :
"   nothing about that heat collector is       a. above COP 1       b. let alone 10,
- each NORMSTANDART Air-2-Air heat-pump has to reach in average in minimum C.O.P. 2
- there is no heat-exchanger,and will never exist,with eta greater/same 1
- yes,heat-pumps are heat collector ,from outside -heat in - (space heating function) or inside -heat out- (space  cooling function)
in English, Portuguese, German or Mandarin " Kishuaheli ? As Tangerine dream https://www.youtube.com/watch?v=AK-lQY6U17c
Yes,it was bespoken several months back : ( was the inventor not killed or died by natural cause ?)
https://infinitysav.com/centrifugalboiler/  heat function,not cooling ! ( But is it not that we can melt by heat water to ice ?)
oil friction work C.O.P. 80 (200 W + 50 W controler) for up to 20 000 W output
10 000 RPM and 200 W rated power : a real good device for Ferreira capacitive winding motor experiments
200 W by ultra-low losts has the advantage of motor self-cooling !
At first from C.O.P.   80     (200+50) /20 000
to                         286     ( 20 +50) /20 000
to                         333     (10 + 50) /20 000
A coupling from several applications to reach C.O.P. > 1000 ,with heating and or cooling function ,non motive (mechanical movement)
                                          for You,nix85,acceptable ?
               Without "occult/esoteric" physics point of view and " If .......,then ......dreamings" ?!
I do not get any "pence" from this NL "heat collector" company,also not from  Infinitysav,but when somebody (private/commercial) offers a good/excellent solution I am the last(personal opinion  ::) ) to deny and not to use this device/method/process if available (ready-to-use/plan) and being costs-attractive !
Successfull weekend wishing
OCWL
nix85
Not as entertaining as you.
"The system COP is > 10, depending on the conditions."
