CMOS Oscillator
Started by synchro1, July 03, 2021, 11:30:02 AM
synchro1
Consider this hollow shaft stepper motor. The shaft can ride on a spring and exit through an overhead hub with a collar key. The setup needs to be stiff and crisp to get the full advantage. A 4 banger with structural arms can cushion it's descent on the main spring.
synchro1
A compact hollow shaft rotary stepper motor and an overhead spline hub to mate with. The central shaft would rest on a strong spring underneath.
synchro1
At 9:58 in Ray's "Magnet Lock" Video he says he measured up to 30 times the COP of sheer to push pull. Equal to the one Floor measured. Below he is measuring 20.
The force to push a ferrite rod with reverse backing magnets through the air core of a ring magnet is 30 times less then the force of the ring magnet field it reverses.
synchro1
Here the backing ring ceramics are visable at the base of the coil. This setup should be 30 times OU.
synchro1
The neo backing magnet appears behind the steel rod. The rotor is visible along with the solinoid coil.
