Over Unity generator from Uzbekistan
Started by rakarskiy, September 06, 2021, 09:02:15 AM
rakarskiy
A generator Over Unity with a flywheel from Uzbekistan from Toyir Kamolov. If you are interested, look for it in Telegram
https://youtu.be/sJVegnu2Ct8
rakarskiy
https://www.youtube.com/watch?v=ZDNpw3ulp44&t=54s
The original design of a self-sufficient converter on two converted motor wheels. The motor-wheel (mover), supplemented instead of the rim, with a massive heavy rim, which in total turned out to be a self-accelerating flywheel-engine. The generator may also be made from the base of the motor wheel, but the external rotor is without a massive metal base and a Halbach Magnetic Assembly is observed.
In any case, to ensure the normal operation of the rim mass included in the motor design, in an original way, a periodic load moment is necessary. The dynamic mass moment works only during acceleration and braking. It is possible that the operation of the generator is organized through the control unit after the assembly of the rectifier bridges.
Chapter for designers about flywheels (Russian)
http://rakarskiy.narod.ru/_ld/0/32_vx8.pdf
https://rakarskiy.livejournal.com/16587.html
QuoteIf a flywheel is used in the drive of the unit with an uneven load, the power of the drive motor can be reduced.
http://rakarskiy.narod.ru/_fr/0/4716753.jpg
stivep
thank you for your comment.
Quote from: rakarskiy on September 07, 2021, 02:33:02 AM
The Halbach Array helps the motor to reach top speed much quicker and is perfect for use in a motor vehicle.
But that is about all it can do.
cons:
1.The device was  presented with no load attached. on the table. here: https://youtu.be/ZDNpw3ulp44?t=146
   The other loads are insignificant. e.g here: https://youtu.be/ZDNpw3ulp44?t=74
2. The  flying wheel  is rotated  and accelerated by  energy of the  hand.
Here are some links helping to understand it:
https://www.stanfordmagnets.com/how-is-halbach-array-used-in-electric-motors.html
https://www.hsmagnets.com/blog/halbach-array-assemblies/
https://buymagnets.com/what-is-a-halbach-array/#:~:text=A%20Halbach%20array%20is%20a%20type%20of%20specialized,field%20on%20the%20opposite%20side%20of%20the%20array.
https://www.duramag.com/techtalk/halbach-arrays/benefits-and-drawbacks-to-using-halbach-arrays/
Wesley
stivep
The right  answer how it works or  how it  doesn't satisfy our expectations:
Правильный ответ:
устройство работает, но недолго *и время его остановки зависит от нагрузки*
Эффект Хальбаха был осуществлен Aмериканцем Джеймсом (Джимом) М. Вайни из Магнепана в 1970 году.
_______________________________________________
Он основан на магнитах, у которых одна сторона стенки Блоха очень сильная, а другая очень слабая и длинная. .
Он очень эффективен для многих приложений. Главный недостаток геометрии массива Хальбаха - сложность сборки. Все магнитные элементы отталкивают друг друга.
Американская концепция двигателя с магнитной левитацией использует постоянные магниты, прикрепленные к ротору, и катушки, установленные на сборке статора рядом с ротором. .
Он создает магнитное поле, используя постоянные магниты, расположенные с изменением ориентации между магнитными элементами на 90 °, что усиливает магнитную силу. .
минусы :
магниты расположены в прямом или квазипрям отталкивающей состоянии. Это означает, что магниты в одном массиве действуют, чтобы размагничивать соседние магниты.
Из-за мелких потерь вроде работает долго .. Некоторые видят в нем БТГ.
Wesley
rakarskiy
Wesley, your analysis is valuable as your personal point of view, but the facts are different. The design is workable, although very rough. There are design engineers who have conducted an external preliminary analysis, where it is clear that the rotation slows down when the external load selection increases. It is unclear whether this is due to an increase in the electromagnetic moment or a voltage drop in the circuit in accordance with Ohm's law. Most likely, the second condition. Obviously, it is necessary to increase the rotation speed and convert the generator to a higher power.
I suggested to him to remake the generator on another design that I am developing, but perhaps its design will also be effective. The main thing is that it works, there is a self-driving mode, with a small external load, about 200-250 watts is already provided by the system.
The material is supplemented with new images provided by the author     https://rakarskiy.livejournal.com/16587.html
http://rakarskiy.narod.ru/_fr/0/2077613.jpg
http://rakarskiy.narod.ru/_fr/0/3264424.jpg
