Kunel patent DE3024814 coil and magnet generator similar to Figuera
Started by norman6538, September 18, 2021, 12:12:05 PM
norman6538
I have not seen anything on this for years but want to speculate on what Kunel said "It works but not as drawn - see if you can figure out how to redraw it".
1. Each fan in an auto had 2 PMs that obviously add some power ie maybe 30%-40% that does not have to come from the electrical source.
2. Kunel shows 1 trigger coil and a magnet at one end and several coils.
3. no Lenz because there is no motion.
4. normal resistance but efficient as a transformer.
5. cascade 2 or more to a stronger setup so that OU 1.25 would be +31.25 x 2 = 62.5 78 x 2 = 156 .....
6. AC so there is not back emf or would DC not down to 0 be better?
Norman
Could that coil be in the middle at the bloch wall with 2 magnets on each end similar to Figuera?
And could there be a complete loop ie. 2 longs and a metal wrap around at the end to carry the flux.
and could the mag be a little stronger than the coil so the sign waver never goes to zero like Figuera?
x. and if the coil is only powerful enough to
synchro1
This is a fascinating patent but it outputs such a small amount of power it is not practical for any porpose. Like running a potato battery.
Quote from: synchro1 on September 18, 2021, 03:29:43 PM
https://manualzz.com/doc/38658459/kunel-patent-de3024814?__cf_chl_jschl_tk__=pmd_o.7563MGjqO29eR3bnuDwbTQ88AY5fIT_NkE_Vo7ClY-1631996104-0-gqNtZGzNAfujcnBszQh9
page 9
if several are arranged such energy producer switched in graduated size e.g. in a series that second receives the full performance first and third the full performance of the second energy producer to etc., then with a multiplicator of 10 in the sixth member of the series already 1000 megW ( or MW) performance are obtained, if one proceeds from 1000 W power input in the first and smallest energy producer at the start of the series.
given theory/claim :
                                     1     2      3     4      5      6           serie
beginning with 1KW x 10 x 10 x 10 x 10 x 10 x 10 =     1000 MW   with DC impulse operating
https://www.yumpu.com/en/document/view/8446313/how-to-build-solid-state-electrical-over-unity-devices-intalek-inc
norman6538
Kunel said he ran his entire house on it.... But unlike the Bessler wheel there were not witnesses that I heard of.
Norman
