GAP Adams pulse motor
Started by synchro1, October 03, 2021, 10:43:33 AM
synchro1
This magnet ampliication video has a unique balance of forces. The BEMF field matches the strength of the backing magets! He recovers the BEMF. The force to mask the magnet is equal to the force of the magnet but in this case is a free lunch! The power side is double the money so the COP is 2.
Magnet Effect on Pulse Motor for performance enhancement - YouTube
This backing ampliication magnet strength to backspike field force ratio is a balance constant for this monopole rotor Overunity build. Romero caught Havana syndrome from this design. Followed by an attempt to have his fingerprints cosmeticaly removed.
synchro1
Neutralization strength is different from Amplification and Adam's masking strength.
The Adam's field reversal not only masks the backing magnets but attracks the correctly distanced oncoming rotor magnet. Proper coil backing magnet strength and rotor magnet spacing generate measured gain. Many builders kill the gain by overpowering the magnets.
The tester measures 120% COP with a loop diode: Then he reduces the input by 33% with the backing magnets. This raises the COP to 2!
synchro1
The reduction in BEMF from reduced input is reinforced by the implosion of the backing field so the total output is the same. Imagine how a Heinrich Kunel solid state generator would channel flux. The input drops but the BEMF continues to output at the same level.
synchro1
An oscillator with magnet backed coils on each side of an output coil with an axial tube traveller spring balanced between the coils would generate power from Mosfet triggered neutralization pulses.
This simpler build has all the advantages of the rotor with much easier timing. The spacing of the rotor magnets can grow problematic. These high perm ferrite cores can tensor in with adjustment screws. Timing the Amplification of the backspike to coincide simultaneously with the chimeric neutralization pulse of its partner. Mosfets enable the power pulses.
synchro1
The measure of coil inductance in Henries drops when the backing magnets are attached. This "negative inductance" is directly proportional to the additional output generated by the implosion of the coils field collapse. This is free energy!
