New Mod to GAGA 3 Motor Produces Output 3X's Input
Started by GravityAntiGravity, December 19, 2021, 09:21:59 AM
GravityAntiGravity
sm0ky2
Tarsier_79
If it actually has 3x the energy, close the loop.
Johnsmith
Quote from: GravityAntiGravity on December 19, 2021, 09:21:59 AM
See YouTube video
youtu.be/R076kP8nPEI
  It would be something if you could change the polarity of something rotating with the generator or one of its gears. Then it could move within
the magnetic field of the generator increasing torque when desirable and decreasing its resistance when necessary. I could see where
that would increase generating capacity over the amount of energy input into the system. Is that what you did?
I think everyone knows that all it takes to reverse polarity is just reverse how the current flows through something by flipping a switch. At the same time
if you can use inertia to increase rotational velocity, all's fair when pursuing over unity. And I give you 10 green dots for your work.
p.s., I forgot to mention, when inertia is something like mv^2/r, then can a weight rotating on a different axis produce the results that you're observing?
With what you've built, something like that wouldn't be obvious when watching a video.
