Build 2
Started by Johnsmith, December 22, 2021, 08:33:09 PM
A good morning (PT-time)wishing , "Johnsmith" !
                                                               KREIS  CRIS/-E/-IS  SPIN
https://de-m-wikipedia-org.translate.goog/wiki/Kreisel?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
        the ccw  or   cw principle !?
        and        principle
        ccw + cw = c²
        RESISTANCE ?
                                          Title : RESONATOR,SELBSTLAEUFER,DYNAMO
                                          Risc : RESONANZ-KATASTROPHE,the point of no return ( HYPER-RAUM theory)
                                          https://de.wikipedia.org/wiki/Resonanzkatastrophe
        ANSWER ?
        cinetics :
                                in FREE ENERGY Scene not an unknown NAME,inventor
        Heinrich Kunel
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=heinrich+kunel&IN=&CPC=&IC=&Submit=Search
        unseen,unanalyzed(by mostly)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=13&ND=3&adjacent=true&locale=en_EP&FT=D&date=19771103&CC=DE&NR=2617553A1&KC=A1#
                      https://www.google.com/search?client=firefox-b-d&q=sonnen-planeten+rad+getriebe
                                                       another ,completting,re-/searcher :
        Andreas Sumera
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=andreas+sumera&IN=&CPC=&IC=&Submit=Search
                                                             Ruhepunkt der UNRUH,
        KIPP-PUNKT
                                                     https://de.wikipedia.org/wiki/Kipppunkt
https://de-m-wikipedia-org.translate.goog/wiki/Kipppunkt?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
        und/and
https://de-m-wikipedia-org.translate.goog/wiki/Unruh_(Uhr)?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
                                                           "Tote(BLIND) Winkel" over-bridging
https://de-m-wikipedia-org.translate.goog/wiki/Toter_Winkel?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
                                                          the Holcomb concept "secret" !?
                                                          HYPER-RAUM and/or  HYPER-ZEIT
                                                           ' Ueber den Dingen "stehen" '
                                               Gedanken sind Dinge   Dinge sind Gedanken
                                              https://de.wikipedia.org/wiki/Transzendenz
                        https://de-m-wikipedia-org.translate.goog/wiki/Transzendenz?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
                               teleological-philosophical-scientifical = mat(h)ematical  R&D answer
                        https://www.google.com/search?client=firefox-b-d&q=relativistische+kinematik
                       https://de-m-wikipedia-org.translate.goog/wiki/Kybernetik?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
                                                  ap-plicare          an-wenden   nutzen use
                                                               theory and practizising
        an help (possibly potential,"potenzieren") :
entering(META) Your personal  BOLISM-CENTERPOINT and self-asking ,and/or following the ,outer-professional(confessional?) MEDI(~Center)-cus/-care(s)/-carrier
        self- respondere self-answering
        8) ;) ::)
                  https://www.google.com/search?client=firefox-b-d&q=youtube+don+camillos+r%C3%BCckkehr
                                                          stupid,ashaming,mysterical answers included !
                                                       https://www.youtube.com/watch?v=JYQoxfYycRQ
                                                          Transzendent,eben(~weil es so ist  ::) ) [plan(~flat),linear,aber auch mit Kurven ]
                                                         " set theory" to "living set practizising" ;) ALL to NIRWANA to ALL
                                                          https://www.youtube.com/watch?v=oa6k11SnToo
        LIGHT TO DARKNESS
Wishing health improvement and recovery and R&D,by step-for-step,success
wmbr
OCWL
p.s.:
  :P   Bessler used a different construction technique and might have invented mercury amalgam (think a dentist's silver fillings for your teeth) forhis bearings.1988 a dentist in DACHAU,civil service for the BUND, "repaired" my theeths,13 teeths became opened and filled with that "TEUG" ,amalgamated ! This was my denture RUIN-ation,in progress ! ::) tanloser TEIgar
Johnsmith
Quoteccw + cw = c²
        RESISTANCE ?
In mechanics and construction , the resonance catastrophe describes the destruction of a building or a technical facility due to excessive vibration amplitudes in the event of resonance .
Die Resonanzkatastrophe bezeichnet in der Mechanik und Konstruktion die Zerstörung eines Bauwerks oder einer technischen Einrichtung durch übermäßige Schwingungsamplituden im Resonanzfall.
With the spinning tops, they can have string wrapped around them so they can be "thrown" to give them a faster spin.
It is possible that Bessler used the pendulum to move counter to his wheel. By this I mean when a weight moves to its overbalanced position, the pendulum would be swinging towards that weight.
Then as that weight swings down, it will generate less torque when it is within 45º of bottom center. This is when the pendulum would start it's downward swing swinging in the same direction the
wheel is rotating. This would allow "chaotic" movement to cause the perpetual mobile (wheel) to rotate at a more consistent velocity/speed.
This is why the pendulum used a cam type mechanism. That would allow for how much the 2 weights at the bottom of the mechanism would rotate as the "spinning top" rotates. Variable timing.
Using such mechanisms might have been to please the observers. Which would amaze you more in 1715? A wheel that accelerates and the slows or one that has a "smoother" rotation? Of course
Bessler might have done it because he liked how the mechanics worked and he could have had some fun with people who wondered how it worked.
If you closely between the 2 views of Wagner's Roaster, it shows that what the external pendulum is connected to. And in the drawing of the wheel, it shows how it is connected to the external pendulum.
Johnsmith
 This is some of the work I've gotten done and some I will be doing. The first 3 pictures show I squared 2 T squares so I would
have something on each side for locating where the dowels will go through the discs. Once I mark the hole locations I'll need
to remove both discs. Then I can use a forstner bit on my drill press (hopefully).
Then when I had the kicker assembly, I'll be able to make a jig so  everything will be mounted the same distance from the axle.
Then when I trim the cues (for lack of a better term) they'll be able to kick the weight wheels outward. The last picture shows
where I chamfered the ends on each side of a weight. This is so when they move to their inner position the pulley mount won't
keep them out. With the short round dowels, I'll be drilling a 1/4 inch hole in the middle. Then I'll use those for spacers on the
weight wheels instead of the more expensive nylon bushings I've been using.
When I get this work done, all that will be left is the catch and release mechanism. And that might after much frustration thinking
about it might actually have a fairly simple solution. And at the end of the day, if this build works then it is an engine or a motor. It
would be performing work which could be mobile. A hydroelectric dam is not an engine because water is what's performing work.
When something is moved or rotated then that is work being conserved. With mass x distance = work. That is actually conserved
work. The energy that requires is work performed by something else. That's if you want it to agree with what is accepted in physics.
Johnsmith
 I thought I'd show you guys the inside of the weight wheel and what it will look like now. The 2 flat ends on the weight wheel
would form a "T" with the arm. The curved sides move towards or away from the axle. Now I should be in a position where I
can work quietly. And with my situation it will be nice to slow down a little.
While I have the discs off, I might go to a fixed position bearing/axle location. Because I marked which 2 bolts on each side
of the hub that I loosened to take the wheel off of the stand, I can put the axle back in the hub  and position it so it is 90º to
the frame.This will add a couple of days of tinkering with it but should allow for a better alignment of all of the different parts.
Basically I'll mount one disc and then the other. With using a dowel to kick parts outward, precise alignment of the axle, frame
and the dowels will matter. And fortunately I now have better tools to work with.
Johnsmith
 With what is shown with the 2 retraction discs lying side by side, I'll need to chisel out locations for the bolts head to be seated in the retraction disc itself.
Since I'll be using a dead blow hammer I'll need to wait until this weekend to do that. During the week I might be able to finish the wheel itself which includes
the weight wheels. This is about aligning both the left retraction discs, the axle and the frame.
To help with that, I made some 90º position indicators. When one retraction disc is mounted to the stand, these position indicators will show very accurately
how the opposite retraction disc needs to be positioned. This simplifies the build process because it allows for mirroring parts. If you try SketchUp which is free,
when you design something, you can scale it. And if you use the value of -1 to scale something then you get the opposite of what you designed. And this would
give the same bolt hole locations on mirrored parts. And with something like the stand, I could've used these 90º position indicators so the stand would've
been to a specific placement. And for tools like a sliding miter saw, table saw, and a drill press, $500 is pretty cheap to be able to do a decent build.
After this, you get into cordless tools of which I prefer. It's just that having the 3 corded tools makes everything much easier. And with the SketchUp images, if
you look at the lower right of the screen, you'll see where ti says dimension. When selecting something to scale, select the part or assembly and then hit S on
your keyboard. And once you start moving one point type in -1 in the dimension and then hit enter. And then you'll have the opposite part. It's just that when you
check what you're building to, it helps to have an actual drawing.
p.s., With something like an engine (perpetual motion machine) it does make it a lot easier. For building other things, if things don't need to be this precise then
a regular drill, jig and circular saw might be all you need. It's just that a lot of wood that comes from the lumber store might need to be cleaned up as it could
be warped or twisted. If you can find boards that are fairly straight then a 90º tool might let you make accurate 90º cuts.
