This one is intresting.
Started by Cherryman, January 19, 2022, 08:54:02 AM
pix
Quote from: Floor on January 19, 2022, 05:33:34 PM
Sometimes I'm just the one in the position to play the critic.
                              It is needed.
       Believing blindly can't help anything.
                         Please...
Don't take it too hard, and don't ever let it stop you from experimenting
if / when you think you see something in an idea or design.
               Best wishes
                         floor
Believe me- I am the last one who could be called "blind believer". :D
Positive feedback phenomena is well known in electronic and audio area.  Uncontrolled may lead to system components destruction. Did you think about it? Are you questioning it's existence? Didn't you hear it for example duing music concerts?  Unbearable noise amplification due to coupling of sound between speakers and microphone?
Exactly the same happens here: generator-el.motor linked and connected together.
I already explained in my previous post why such "self running" system may work.
It is not "free energy", energy is coming from: initial run done by operator, and permanent magnets magnetic field.
It is a system that conserves and accululates energy due to positive feedback.
Cheers,
Pix
pix
Quote from: skybiker63 on January 20, 2022, 05:41:20 AM
There are several who wants to try it, by my opinion it sounds interesting  :o
Yes.  :)
skybiker63
We need to check the right components to make no mistakes,
we should help each other and work in a team.
Please double check...don´t know if its correct:
One Phase Motor from UTENTRA 220V and 2800RMP 220V
Car Alternator 24V 200AMPS
(perhaps from Audi Quattro made by Valea)
Magnets seems to be Arc Magenets, not totally flat (important you cannot replace the two little magnets by a single larger one as it would create totally different waves)
We should create a parts list and where to get the parts from
pix
Quote from: skybiker63 on January 20, 2022, 08:59:37 AM
Why not?
Most important is alternate magnets polarisation N-S-N-S to be on exact position facing stator coil loop. When one side of coil loop faces N the other side of that coil loop must face S.
I guess guy on the movie didn't had longer magnets, that's why he had to glue two together.
I don't see other explanation.
Look at principle, don't blindly follow his setup.
Here you have similiar principle, difference is- starting of unit is done with grid energy spinning electrical motor, then power supply is disconnected , instead of manual spinning.
Infinity SAV – Revolutionary technologies for a better tomorrow
Cheers,
Pix
Floor
partial quote
Quote from: pix on January 20, 2022, 05:42:45 AM
partial quote
cool / cheers
    floor
