This one is intresting.
Started by Cherryman, January 19, 2022, 08:54:02 AM
e2matrix
Quote from: pix on January 20, 2022, 05:42:45 AM
Believe me- I am the last one who could be called "blind believer". :D
Positive feedback phenomena is well known in electronic and audio area.  Uncontrolled may lead to system components destruction. Did you think about it? Are you questioning it's existence? Didn't you hear it for example duing music concerts?  Unbearable noise amplification due to coupling of sound between speakers and microphone?
Exactly the same happens here: generator-el.motor linked and connected together.
I already explained in my previous post why such "self running" system may work.
It is not "free energy", energy is coming from: initial run done by operator, and permanent magnets magnetic field.
It is a system that conserves and accululates energy due to positive feedback.
Cheers,
Pix
Very aware of audio feedback but where do you think the power for it comes from?  It comes from the outlet it is plugged into or a battery pack which can keep providing more wattage until components either fry or someone turns down the volume quickly.   What you have in the fake video has no source of power to tap into.   The only devices like this I've seen that 'might' work are ones with a large heavy flywheel.   But please do prove me wrong by building it - I will gladly eat my words and thank you for a successful build.
pix
@e2matrix
I am not going to argue with you.
Once I will do my project I will let you know.
The  plan is to modify ansynchronous motor instead od car alternator. More windings in the stator.
See examples.
Генератор на постоянных магнитах. Как сделать. Подробно. - YouTube
[size=78%]Асинхронник на магниты 1,5 кВт - YouTube[/size]
Cheers,
Pix
skybiker63
It is elementary neccessary to use the two single magnets instead of a normal one.
If you use the normal one it becomes a common generator.
As normal Generator it has no OU.
Two little magnets cause totally different magnetic fields than a single magnet, specially in this arangement. You can clearly see in the video that he has to push them hard together, this position cause
new kind of magnetic fields.
Another point is that also an arc magnet creates other fields than a flat one...magnets arangements are not such an easy job of South and North... :o
The whole arrangement and construction is only looking so simple but in detail I can see a lot of great detail work.
pix
@Skybiker63
It IS a common generator, no OU there.
The special thing about such a setup is to loop and accumulate  excess energy for use. I already explained this.
Many builders use small magnets because they are more available and cheaper, long magnets are not common and very expensive.
It is important to locate magnet in "tilted" position against line of coil, this is to reduce a drag.
There ia a Polish thread about such PM generators for homemade wind turbines, 400+ pages, everything is there.
Most common to modify with PM's is a washing machine motor or 3 phase ansynchronous motor- they range lies in kilowatts. Typical car alternator may produce max. 500Watts.
e2matrix
If you want to try a much stronger alternator to do this with try getting one used on big trucks (18 wheelers) as they can put out much higher wattage.  Used ones can often be found for not much more than car alternators.  Even new ones aren't that much as you can see here is one that can do 160 Amps (at 12 volts thats 1920 watts) for $93 and that was just a quick search on ebay:  https://www.ebay.com/itm/174169073394
Car alternators on the other hand are typically around 65 amps if I recall.
Also note you can easily resize your pictures with this old version of Paint Shop Pro - very small and easy to use and still works on new Windows versions:  http://www.oldversion.com/windows/paint-shop-pro-5-0
