Building an OU Motor/Generator combination
Started by MWestland, March 05, 2022, 06:58:10 PM
Dbowling
Repulsion/ Attraction/ Repulsion. And power is produced because there is still a change in flux. If the attraction is equal to the repulsions that's a free spinning rotor. Can the magnetic "assist" from the permanent magnet be varied enough to make that happen.
Jimboot
Thanks for that. Tests tonight. My Hall effect switching circuit had no measurable effect by placing pm on the em core. On my reed switched motor it took current draw from 90ma to 50ma immediately and began to speed up. Using hand held pm with opposing pole facing the rotor, the motor sped up but drew an extra 40ma. I put the scope across the drive coil and the pulse width had increased slightly. So the extra on time drew more current but even though I could feel a slight cogging the rotor sped up mmm
Paul-R
BorisKrabow
Quote from: MWestland on March 06, 2022, 03:44:12 PM
Boris,
I had a thought. I KNOW you can affect the Lenz reaction in a number of ways. Change the length of the core material, its composition, etc. Increase the capacitance of the wire. Change rotor speed.
Hey ! I understood . You want to fit a lot of effects into one device.
To quickly get free energy.  It's like engineering humor, but it's possible.   ;D
    voila . Here the ideas of Kromrey, Ed Leadskalnin and many others are combined.
     Let's look at the picture. The magnets pass through the turns of the coil without reaching the core of the coil.
     As soon as a magnetic field appears, the core attracts Lenz .
    The core of the coil is made of a long soft iron rod.   a long rod of soft iron carries Lenz away from the coill.
    Foucault currents in soft iron convert Lenz into heat.
    The faster the rotation, the stronger Mr. Foucault becomes.
