SolarLab
lancaIV,
This is the patent the latest (Japanese) patent is based on:
US5926083  Asaoka
Same fellow, the latest patent shows some improvements
and talks about the performance of the US Patent.
From what I've studied so far, these patents are well worth more analysis!
Thanks again,
SL
Asaoka/Ogino their R&D ,together with Flynn Bros. and Jack Hilden Brand magnetic valve ,was forum theme standart 2006-2007 !
With improved electro-magnet technology,pulsed/capacitive/sc coil,the 2023 standart is by 100% improved !
https://patents.google.com/patent/WO2010003394A3/en
or
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20091130&CC=PT&NR=104078A&KC=A#
wmbr
OCWL
SolarLab
From the most recent patent it is noted:
"In order to put the prior invention to practical use, the invention has undergone repeated
practical tests in order to increase the input/output effect by at least 2.0 to 5.0 times
or more and to maintain continuous power generation performance over a long period of time."
"As a result, even in a permanent magnet with a high magnetic flux density, the magnetic flux
density is significantly attenuated depending on the length of the magnetic flux path, so the
yoke must be formed as short as possible
"The inventors have discovered that it is extremely effective to control the closed magnetic path
and open magnetic path of the permanent magnet in the vicinity of the permanent magnet, and
that the input frequency has a large effect on the output power ratio to the input power,
leading to the present invention."
Probably worth studying/Analyzing all these patents by Asoaka. Some interesting stuff!
And they are about as simple to build as it gets... Appears a single cell has about 1.5 to 2.5 output.
To quote from the patent:
"... in the practical application test, in the case of a high frequency input power of about 3,000 to 30,000 Hz,
the input power / The output power ratio has been confirmed to be about 1.4 to 2.6 times."
SL
Yes,that is to read !
Rotorverter : battery or capacitor 1 input to electric motor,100%
                       battery or capacitor  II input  from generator,+- 30%
                      100%/30% = 3,33
                      Between battery/capacitor I and II an electromagneto-motive force amplifier with
                     with ' work process C.O.P.  3,33 ' gives :
                    external energy free heat pump work nonstop
                   and
                  mono-/bi-/tri-/quad-cycle mobiles a long drive range !
                 Rotorverter generator coil with David Yurth dielectric material coating :
                 'work process C.O.P. 2,5 ' sufficient
                  Rotorverter generator coil treatment and Rotorverter motor improvement
                  ' work process C.O.P. ≤ 2' sufficient .
                  Asaoka/Ogino and Dr.Pavel Imris capacitive coil devices let reach this  !
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=3&adjacent=true&locale=en_EP&FT=D&date=20161013&CC=DE&NR=112014005978A5&KC=A5#
(0029) Zum Beispiel, in Reihe 3 sind 140 V Spannung und 6, 66 Ampere Blindstrom. Bei 50 Hz Frequenz ist die Blindleistung 935 VA und die abgegebene Wirkleistung ist 850 W. Die aufgenommene Wirkleistung in den kapazitiven Wicklungen 3, 25, 26 ist 24,31 W. Alle anderen Reihen in Tabelle 1 beweisen die physikalische und technische Funktion der Erfindung weiter. Die experimentellen Daten in Tabelle 1 illustrieren das Verhältnis zwischen der eingesetzten Energie (Säule g) und der abgegebenen Energie (Säule f) im vorliegenden elektrischen Generator. (0030) Technisch ausgedrückt ist das ein Verhältnis vom Energieausstoß zum Energieeinsatz, auch Nutzungsgrad genannt. Der Leistung des Generators gemäß der Erfindung stehen Fachkräfte im heutigen Stand der Technik mehr als skeptisch gegenüber. Es ist wichtig zu wissen, dass die physikalische und technische Funktion des vorliegenden Generators ein Teil einer Entdeckung auf dem Gebiet Masse-Energie-Beziehung ist. ....... '
(0029) For example, in row 3 there is 140 V voltage and 6.66 amps of reactive current. At 50 Hz frequency, the reactive power is 935 VA and the active power delivered is 850 W. The active power absorbed in the capacitive windings 3, 25, 26 is 24.31 W. All other rows in Table 1 further prove the physical and technical function of the invention . The experimental data in Table 1 illustrate the relationship between the energy used (column g) and the energy delivered (column f) in the present electrical generator. (0030) In technical terms, this is a ratio of energy output to energy use, also known as the degree of utilization. Experts are more than skeptical about the performance of the generator according to the invention in today's state of the art. It is important to know that the physical and technical function of the present generator is part of a discovery in the field of mass-energy relations.
Blindstrom zu Wirkstrom Konvertierung : apparent power to real - active- power conversion
by Biot-Savart law mechanics apply
F= BIL to F= BILsin
https://www.google.com/search?q=F%3D+BILsin&ie=utf-8&oe=utf-8&client=firefox-b-m
A physical world,where 1/0= by orthodox -abstract-arithmetics means ' Syntax Error' ,in Applied Formula Physics gives ' concret useable results',repeatable !
Ex-'electron',today called ( hydrogen-) ' ion' ,as gas ' plasma', displacement work process
https://en.m.wikipedia.org/wiki/Compton_scattering
The analog phenomen ' recombination phase time' in n-p-n/p-n-p photon/phonon cells devices ,+ avalanche effect ( domino-/butterfly-/chaos- effect,resonance - plus ultra- catastroph )
https://en.m.wikipedia.org/wiki/Cooper_pair
                  An alternative to battery/capacitor I and II static dynamo is a
                ' double motor- ccw/cw- gear- generator' couple
                 and/or '  mo-ge-gen with motor+ amplifier( motor input side)
                  and generator+amplifier(generator output side)'.
                 Sincerely
                 OCWL
                 p.s.:
                Also mentioned 2006/2007,step-by-step improvement R-/S-&D time
inventor :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Adolf+zielinski+&CPC=&IC=
applicant :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Adolf+Zielinski&IN=&CPC=&IC=
kolbacict
