Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
0 Members and 33 Guests are viewing this topic.
listener192
This was the last iteration using a series parallel scheme to increase coil current.
Quote from: listener192 on March 30, 2022, 03:39:41 AM
Read from this point  https://overunity.com/17653/pierres-170w-in-1600w-out-looped-very-impressive-build-continued-moderated/1350/
Reply #1376 on: December 20, 2020, 06:30:22 AM ยป Quote
'open DZ2 ' compared 'enclosed micro wave owen chamber with rotating disc'
and EMdrive https://www.google.com/search?client=firefox-b-d&q=emdrive
https://www.popularmechanics.com/science/a35991457/emdrive-thruster-fails-tests/
The EmDrive, copyrighted by its parent company SPR Ltd, theoretically works by trapping microwaves in a shaped chamber where their bouncing produces thrust. The chamber is closed, meaning from the outside, it will appear to simply move without any fuel input or any thrust output.
Sincerely
OCWL
pmgr
Quote from: Ufopolitics on March 30, 2022, 04:17:57 PM
Hey PmgR...are you trying to read my mind, or guess here, assume my thoughts now?...hahahahaha
Yes, I have a bit of that supernormal capability, mind reading
Man, of course, I know very well in Pierre's design, the Outer Core are the Rotating Fields as the Single Inner Coil is the Stator, or Secondary where output is taken from...Duh!
(I just do not want to take your comment above seriously... so I rather laughed).
Yeah, that was for anyone who would mistake the center piece as the rotor, since it is n the rotor place and that was what it was called in Pierre's thread. So no, that didn't apply to you 8)
Magnetic Fields DO ADD UP as simply as 2+2=4, depending on how they are set spatially.
So, I see you've got "all the answers" as why it does not work?!!
Did You Replicated this setup from Pierre, PmgR?
I am not saying I have all the answers, but I did simulate that rotor/stator configuration in FEMM and played around with all kinds of configurations to see where the flux would go. Even calculated flux couplings to the stator for different rotor positions. Anyway, what came out of that is that the total field in the stator is the sum of the field of all poles, but that is also equivalent to the field of one pole pair + that same field of that pole pair shifted by 120deg + that same field of that pole pair shifted by 240deg (spatial 3 phase geometry), so in total it sums to zero. Hence barely any flux with this 6 pole configuration in the stator. Similar to how 3 electric phases cancel out when added up.
All the replications found the same thing as my simulation results (no flux in the center iron) and that begs the question: what did pierre do different so he got a large flux coupled through the stator; he basically got 120-140V AC out of that stator while all the replicators only got maybe up to 10V out on their initial tries.
PmgR
Ufopolitics
listener192
After reading the patent in some depth, this is a summary of the action of the device.
The rotating outer N-S DC poles develop a small three phase output in the output stator. The steel in the outer rotor (patent reference) is close to saturation. The inner rotor coils are wired as a three phase 4 pole motor and are driven by this small output from the output stator coils.
This will develop a travelling MMF wave back into the output stator (see attached animation) and its this MMF that really pushes the output voltage up in the output stator coils.
The variable amplitude flux shown on the patent drawings for the inner rotor coils, is the flux due to the MMF travelling wave.
Due to the file size limitations on this site, here is the link if you wish to run the GIF  http://www.ece.umn.edu/users/riaz/animations/sinvec.html
The synchronism between the outer stator pole phases and the inner pole phases is important so they totally reenforce, hence the design has rotational alignment requirements in the initial setting up of the device.
L192
listener192
It now makes me wonder if there is some merit in the attached device which appears to cut out  the middle man so to speak, by driving a stator with a three phase current and via a set of additional windings allows an output of 3 phase current, at first sight a rotary transformer however, the inventor is insistant that the traveling MMF wave provides additional induction/output on top of the flux linked output.
L192
