Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
pix
I still can't see a difference between Holcomb "non mechanical rotation generator"  and  AC slip ring motor with locked rotor.  ;D
Apart from complexity....
Cheers,
Pix
rakarskiy
Quote from: pix on May 26, 2022, 06:17:20 AM
Cheers,
Pix
Or with an AC motor with a phase rotor.
In Ukraine, by the way, they immediately suggested using the installation of an AC motor with a phase rotor, fixing the rotor to counteract rotation, as a variant of a static converter. I don't know if the author implemented the idea.
If it is possible to excite a rotating field in a fixed phase rotor, it must be taken into account that the supplied excitation energy will be many times less.
bistander
Mr. Radarkskiy,
What is a "phase rotor"?
bi
Mr. Pix,
I agree. I think most do not realize, not comprehend or just don't believe the rotating magnetic field (commonly referred to as RMF) found in the 3-phase machines.
bi
rakarskiy
Quote from: bistander on May 26, 2022, 03:33:11 PM
Mr. Radarkskiy,
bi
Mr. Pix,
bi
https://youtu.be/JPn5Ou-N0b0
https://kiev.prom.ua/p1556480543-elektrodvigatel-faznym-rotorom.html
onepower
bistander
QuoteI agree. I think most do not realize, not comprehend or just don't believe the rotating magnetic field (commonly referred to as RMF) found in the 3-phase machines.
This reminds me of populism and a nursery rhyme called "Humpty Dumpty". In every book they show Humpty as an egg which supposedly falls off a wall.
In fact an egg has nothing to do with the real story and Humpty Dumpty was an English cannon, lol.
The English were being bombarded in a fortification and there cannon called humpty dumpty fell off the wall it was mounted on and could not be put back together again.
The popular story of a rotating magnetic field is similar. It's not a real field rotation because a magnetic field cannot rotate.
In fact, it's a progressively switched(Sine Wave) field which uses flux linkage to emulate a field rotation.
As one magnetic field/coil forward expands another magnetic field/coil behind collapses.
The flux linking between coils, links them, appearing as a single field when if fact it is switched.
The first clue should have been the term AC or alternating current. Logically a field cannot truly rotate when it ceases to exist in between an alternation/reversal.
The field expands(N) then contracts to zero then expands in an opposite polarity(S) then contracts to zero and repeats this cycle.
So we should be clear this expansion/contraction/flux linking may appear to be a rotation just as blinking christmas lights appear to move in a linear fashion however it is not a true field rotation... it's an illusion.
In my opinion it is these kinds of false beliefs,ie. field rotation, which hinders a persons ability to learn.
It's simply not true and cannot be justified with any real facts or justification.
AC
