Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
forest
bistander
Quote from: forest on December 29, 2022, 06:31:39 AM
How is Lenz action possible when current is steady ?
Hi forest,
Quick review:
QuoteLenz's law states that the direction of the electric current induced in a conductor by a changing magnetic field is such that the magnetic field created by the induced current opposes changes in the initial magnetic field. It is named after physicist Emil Lenz, who formulated it in 1834. Wikipedia
QuoteFaraday's Law
Any change in the magnetic environment of a coil of wire will cause a voltage (emf) to be "induced" in the coil. No matter how the change is produced, the voltage will be generated. The change could be produced by changing the magnetic field strength, moving a magnet toward or away from the coil, moving the coil into or out of the magnetic field, rotating the coil relative to the magnet, etc.
from: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/farlaw.html
Lenz's law is only qualitative, gives polarity. Faraday's Law describes, or dictates the phenomena.
So a constant magnitude current (DC) will have a magnetic field.* Any relative motion between the magnetic field and the current carrying conductor constitutes a change satisfying condition for Faraday's Law. That's how DC can induce voltage, and current. Lenz tells polarity.
bi
QuoteA magnetic field is a vector field that describes the magnetic influence on moving electric charges, electric currents, and magnetic materials. Wikipedia
ramset
Sir
It would be better to write
You are not familiar with how this is possible ( some proprietary feature or technique must be present?
For clarity very recently there have been many curious comments on the "off forum grapevine "
However there is also a 200kw unit in the pipe ...for delivery?
And there are "some" happy customers...
Respectfully
Chet K
Thanks Grandma
bistander
Quote from: ramset on December 29, 2022, 08:18:33 AM
Sir
Respectfully
Chet K
Am I allowed to write this?
With regards to all current scientific knowledge, that claim is impossible.
bi
Ufopolitics
Quote from: listener192 on December 29, 2022, 06:22:23 AM
It is also noted that Holcomb claims that an electrical rotating rotor can be inserted into any standard three phase generator stator and produce output efficiencies above 100%.
So this arrangement implies the rotor is the key element, as there are no stator non conventional geometries used.
Can any of you explain how this can be?
L192
Hello L192,
Guessing you meant by "an electrical rotating rotor" as a non mass rotating rotor, where it is just the magnetic field spectrum rotating, correct?
Now, my question is simple:
Have any of you guys (who oppose to this claim) done this test yourselves?
Only those who have built and done such claimed test, could be able to refuse it.
And of course, present your test video as a refusal proof.
Otherwise is pure air blow...
Plus, it is not "any" rotor, but must match* the number of salient poles on the stator, and so, *matching not necessarily means having same number of, but being multiple of such number.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
