Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
SolarLab
BS - Your quote "fluf" and "hysteresis" says it all - not need for further discussion.
Ramset -  works for everyone else. Try something else...
Have a good one!
SolarLab
THIS IS THE FIRST "EXCESS ENERGY" SCHEME TO BE PRESENTED TO THE
WORLD.  IT'S EASILY REPRODUCABLE BY ANYONE SKILLED IN THE ART!
And these guys are worried about really stupid stuff like "my link won't
work" and "the B-H Characteristics are bogus."
YOU MUST BE KIDDING - DO YOU ACTUALLY REALIZE THE IMPLICATIONS?
rakarskiy
Quote from: SolarLab on January 08, 2023, 11:45:06 PM
SolarLab.
This is a bold statement "FIRST!". Even in recent history, it is far from the first, there are those designs that "seeing townsfolk with chewing gum in their mouths" have not even seen!
For example, this patent: Energy management system US9620280B2
https://patents.google.com/patent/US9620280B2/en
QuoteAbstract
A split-flux transformer has a primary or input coil, at least two secondary or output coils, spaced apart and arranged in 3D, a magnetic core running through the primary and secondary coils, a source of electricity connected to the primary coil which when turned on creates a magnetic field in the core, and electrical wires connected to the secondary coils, each of which provides additive electricity into an output circuit.
https://weareinfiniteenergy.files.wordpress.com/2018/06/sft_principle.png
The US Patent Office did not issue a patent until two valid designs for the claimed effect were submitted. Photos are placed in the text of the patent.
https://patentimages.storage.googleapis.com/7a/6c/da/1533c5d57edde9/US09620280-20170411-D00005.png
Today I can say 90% how this device works.
Another example is Stepanov's systems, they also implement devices with a performance greater than one. True, their systems are not openly disclosed.
http://sth-technology.ru/
I don't even name electromechanical systems. Therefore, never claim if you do not know something.
pix
Quote from: SolarLab on January 08, 2023, 08:02:48 PM
Actually, a careful examination of the "iron" B-H Curve does explain the energy gain very well. A small input energy
"H" yields a very large energy "B" out. Convert the units if you find it confusing. Hysteresis is only one part of B-H
as you should know.
Typical trap where "free energy enthusiasts" fall.
When they think that hysteresis of ferromagnetic material is the source of free energy.
You forgot to continue your phrase, that amplification of H field by soft ferromagnetic material works both way.
As soon as that amplified B field causes induction in the coil, that coil creates counter magnetic field opposing the first one. And that counter H' field needs to be equally small to H field to create amplified counter B' field.
Otherwise all commercial generators would be "free energy" devices....
Cheers,
Pix
rakarskiy
Quote from: pix on January 09, 2023, 05:38:55 AM
Cheers,
Pix
Why do you think so?
In a synchronous generator, the excitation field and the phase field add up, no matter the winding wires in the groove or on the rods in the coils.
QuoteThe field of the machine under load will be created by the joint action of the excitation and phase windings. It will be different from the idle field.
The effect of the armature magnetic field on the machine field is called the armature reaction.
First, we will consider the reaction of the anchor, keeping in mind the qualitative side of this phenomenon. Quantitative accounting of the armature reaction, as well as internal voltage drops in the armature winding, is carried out using vector diagrams, which will be considered later.
A synchronous generator can operate with lagging or leading current in relation to the E.M.F. , given by the flux of the poles, or with a current coinciding in phase with the E.M.F.
It was the decomposition of all actions into components that helped me to understand this. Even the magnet and the ring don't work the way you imagine. It is enough to put the core in the ring.
