Energy Generation by moving Mag Field through Static Steel Core & Copper Coils
Started by Ufopolitics, April 07, 2022, 09:40:19 AM
Ufopolitics
Resuming...
Anyways, no matter what, it is great to see that someone, on the other side of the Globe...is also trying to work on this... :)
As it shows that there is an Induction generated by just rotation of the Virtual Field through the static steel cores and coils...
As I mentioned before...this is just a simple testing to observe, read your parameters...as the same rotary switch could be used to drive much bigger fields on larger machines...
Eventually there could be done a better winding, specifically designed for a higher field density and strength on the Armature or Static Rotor.
What I really want to test...is the posibility to loop the output to the Input, after ac from output passing diode bridge and running small cap...to the input...then disconnect PSU... :D
I will be very happy, if this could be achieved...even if a second load could not be added...but eventually allow us to add specific secondaries at 90 degrees from main output coils (in order not to upset mains)...just to loop Exciter...like any small single phase generator does... ;)
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Hello to All,
Again, I want to thank Member RhineX for sending me the links to the Google Patent of this device build by Jae-Soon Park (the Korean guy), that I previously posted his tests...
Here is the link for the USPTO Patent link: PATENT # 8629588
And I could not believe this guy patented his tests!!...which were meant just to do that, test, research, experiment, improve means to output better results...etc,etc.
And He is still adding the huge motor (on pat images) and the same type of armature arrangement, which already exists in all Universal Motors Lap Windings...
An "off the shelf", OEM, Universal Motor, like he shows, -on his tests, and on his patent- will never, ever, output the same way as a dedicated Generator-Frame and Windings will do, based on number of turns, wire gauge, spatial  distribution of the coils, which could have included Three Phase Windings, plus the looping coils to feed exciter or stationary coils here... etc,etc...
He just spent the money, hire attorneys and patented an unfinished product...maybe, because he was "excited" by his results...then decided to "protect" his idea/invention...from others who may steal it...
Anyways, this test is just what I said previously it is...a simple test, it will get way more complicated later on...it is just so you can see what happens here...compare Input versus Output numbers, measure Amps and Volts In-Out...What happens when loaded?...check which best RPM is suited for a better Output Sinewave, seen on a Scope...add then running caps...and retest...and so on and on.
One of the issues I have found on these system from my previous experiments...and now I have seen it on one of his videos below, as it happened exactly the same way to me:
On this video HERE, at  minute 0:43 He shorts the output with his hand (Picture attached)...bulbs go off...and unless we are talking about 12 V and low amperage, stioll is AC, no diode bridge here...and let's realize these are incandescent bulbs, not LED's...
The Currents on the Output show they are higher in size than at Input...however, if you get the output and short it...say at 3 Amps...no sparks take place at all....the output just collapses (I have done that)...on his videos the two incandescent bulbs just turn off...and of course, the prime mover, turning the brushes is not affected by the short as they are two completely independent circuits.
But the issue here is that even looking as a higher Output, on V&A, Amps does not have the "real power" as they represent on the readings.
I mean, if you just touch, 120 Volts and 3 Amps in AC Output, you will get a shock!!...but not here...
This issue could be resolved, but not simply...we will have to modify the Exciting Armature, structure and windings...
What I think is happening here, is the fact that a Magnetic Field backed up by a moving steel core (like we have in all rotary generators), will enhance, add more density to the power output... much more than just the virtual field rotation on a full static steel core...
But, the solution would be shown after I make it work, and be sure it does solve this issue, (still some time until I make that specific armature structure and windings)...as I have to first test the simple Universal Motor...and do all this measurements and tests.
Cheers
Ufopolitics
Edit 1: I just noticed when uploading images here, on MAIN DIAGRAM_2...that he uses an Inverter, to feed back output power back to brushes (Input) through a battery...I mean, I hope he is referring to a simple Diode Bridge...and not to a whole inverter set...
―Leonardo da Vinci
Ufopolitics
PATENT 8,629,588 CLASSIFICATION:
H02K53/00 - Alleged dynamo-electric perpetua mobilia
Perpetua mobilia obtained e.g. by
by combining electrodynamic machines (e.g. small motor driving a larger generator whose output is used to feed the driving motor;)
by particular arrangements of PM (permanent magnets) only.
This is the typical response from any Patent Office in the International Commonwealth of Patent Treaties...
Whenever an individual walks in their offices claiming a "combination of electrodynamic machines"...where a small motor (or circuit) is driving a larger generator, then looping it all...
You can NOT Patent Free Energy System guys!!...do not insist!!...It is money and time wasted!!
No one will even pay attention to your invention.
Ufopolitics
―Leonardo da Vinci
Ufopolitics
NOTICE TO ALL:
I would  NOT, under ANY circumstances, allow nor accept, ANY Nay Sayer's Comments here, on these Threads.
That is the ONLY reason I accepted to DISCLOSE HERE...as a Moderator , thanks to Administrator of the entire site, Stefan Hartmann and to "Chet" RAMSET.
So, if you post any "Nay" saying comments here...and you are still "seeing it" ...you may need to REFRESH  your browser, which resets your "Cache Memory"..
Or it could be that I am not logged in, or away from the website...it will not take long, though, as it will get done, in time...
This Thread is intended ONLY for people willing to do (BUILD) all future tests and share them, verify their results HERE.
Images, at least, should be posted of your progress, but videos would be more suitable.
I will allow any willing builder to open his-her thread under the main one.
All others, please, just remain as viewers...and like I always write on all my videos: many thanks for watching!!
Respectfully
Ufopolitics (Moderator)
―Leonardo da Vinci
citfta
Hi Ufo,
I hope you don't mind if I ask a question about this topic.  I think I am missing something.  I don't understand what the difference is between this machine with the rotating brushes and a regular car alternator.  Both of them are moving a magnetic field inside the stator coils.  And both of them maintain a continuous strength magnetic field.  So what makes the machine of this thread any better than a car alternator.  What am I missing?  Am I misunderstanding what I am looking at?  Thanks for any clarification you can give.
Respectfully,
Carroll
