Energy Generation by moving Mag Field through Static Steel Core & Copper Coils
Started by Ufopolitics, April 07, 2022, 09:40:19 AM
Ufopolitics
Hello to All,
First, I would like to thank Pierre Cotnoir for showing his setup, plus the moderated Thread by Gotoluc...unfortunately now gone south.
All this readings and watching his videos, make me realize what I was doing wrong in all my experiments in these fields about seven or eight years ago...
Do to these exhaustive experiments done many years ago, trying to get just the Magnetic Field moving within the steel cores and windings...then just by seen Pierre's videos, and reading his comments on that Thread, I realized where was my main error, and to put it in simple words:
I was collapsing the Magnetic Field...
And this is the crucial point here!!...the whole, main field can NEVER DIE!!, not even for one millisecond or even one nanosecond...So, you could switch a minimal number of coils at a time, but ALWAYS leaving the majority of coils which configure each Pole, turned on.
Then the words from Thomas Bearden, (Rest In Peace) kept pounding on my ears: "Whatever you do...don't ever, kill the Dipole!!"
If you collapse the main field by cutting off its feed, even for a fraction of a second, everything will have to restart again from scratch...and so, you will never get to generate a growing, development over time of energy output...simple.
And of course, there are some other "secrets" involved to make it more and more successful...however, I would not keep any of these secrets just for me here...my point in opening this Thread, is that You will also be successful reproducing this effects...as that would be my "protection".
I will start, like I always do...when I disclose something that eventually will become more clever, more complicated...and that is by first starting by a very simple experiment...very simple.
A long time ago, I built a small mechanical Rotary Switch, which could commutate a series of coils remotely...by just wires transfering the switching.
And NO, you can not just buy it "off the shelf", or "order it on line" anything that even looks similar to this type of switch...so, yes, it has to be built from scratch.
This Rotary Switch I used it to run the 1908 Clemente Figuera setup...where the Field is only moved forward and back, by step up, step down, just by the High side or Positive feed...so, my rotary was set with only one brush feeding the coils, while negative ground was always connected.
However, I had the original switch set with dual slip rings...and now, I had to dust it off...and reset it for dual brushes sweeping on a 16 elements, brand new commutator...I am still working on that...
This way, I will be able to show a system working without a lot of clever circuits, consisting on a bunch of relays, or FET's...and Microprocessors, like an Arduino or a Raspberry PI...or any other Programmable Logic Controller....plus writing codes, etc,etc.
I will put it in straight Black and White, for sake of the simplest understanding first.
And attached is an image of this simple test...diagram, that I would be testing and adding a video very soon.
The Rotary Switch should be build with heavy contacts, which could be used also for higher voltages and amperages in the future...while a very small motor will be in charge to just rotate the brushes and slip ring...and I will  keep adding images of my progress here...
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
BASIC MAIN WINDINGS AND CIRCUIT OF GENERATOR STATOR PLUS STATIONARY LAP WOUND ARMATURE
Here I will show a Diagram of the Basic Winding which involves a Generator Field (Green outer windings of a Single Phase shown here, without showing the rotor exciting coils) and the Inner Stationary Rotor...which is basically a typical Simplex Lap Winding, however (and this is the first secret) that the size of the main poles, (here are just two Poles) must MATCH the Generator Output Coils width.
Now, the good news is that we could find this whole similar set up in an Universal Brushed Motor...already wound from factory, with balanced coils in size and in number of turns, in Armature and in Stator... ;D
These type of Universal Motors, as also the Permanent Magnet ones, have a Lap wound Armature...and they perform by keeping an ALWAYS ON AND STATIC Magnetic Field...and in charge of the Rotation are the series connected coils constantly rversing their Polarity in Voltage hence in Magnetic Poles...
So, no matter how fast this rotor is spinning...the Magnetic Field will always remain static, lingering spatially all the way to interact with the coils on the Stator.
Then what we will be doing here...is just the "Reverse Engineering" of the whole system...which means to keep rotor static, firmly attached to main frame, keeping an air gap...where we could just use high temp tape that we use for coils winding...instead of the air gap.
And then rotating just the Magnetic Field by rotating the Brushes with our simple Rotary Switch... ;)
―Leonardo da Vinci
Ufopolitics
FURTHER EXPLANATION ON THE SIMPLEX LAP WOUND ARMATURE
So, all these coils in the armature are connected in SERIES in a FULL CLOSED LOOP...with a "Y" derivation to each commutator element from each coil...
And brushes, typically set apart by 180º, are in charge to DIVIDE this Stationary (on motor) Field Poles in North-South...and this imaginary line between the two brushes, comes to be what is called as the "Bloch Wall"...which is normally PERPENDICULAR to the Stators Coils dividing line.
When the Armature is energized (Positive and Negative) through the brushes, there is immediately developed a full Attraction and a Full Repulsion at each Magnetic Pole, forcing the Rotor to "spin"...but what is actually taking place is that one of the coils of each pole side are reversing their polarity, by "passing to the other side" of the Magnetic Field, defined by the Brushes imaginary line...while Field is completely Static.
The great side of these type of windings, is that Currents are kept on the low side (and pretty constant) during operation, no matter how high we dial the Voltages up...which keeps the Magnetic Field very stable.
Explanation of the attached Image:
It is an Upper View of a typical PM Symmetrical Motor, where I have painted all coils with the same color as the magnetic pole where they are "momentarily" energized by the brushes...so Red are South Pole Coils, and Blue are North Side Coils...and this is an image taking place in a fraction of a second...as they are constantly exchanging from one side to the other side of the Static Magnetic Field....
If you notice the Field is always ON and Static, while majority of coils are energized polarizing the Field main poles...as ONLY TWO COILS AT A TIME (one coil per pole), are switching or reversing polarities...this is exactly what we need for our test.
To be continued and keep checking for further editing
Cheers
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Hello to All,
Thanks RhineX for sending me the video links!! :D
About this guy in Korea, who is doing very similar experiments (2016-2018) as the test I have proposed, and that I am working on at the moment...
They say He is getting somewhere around 170% COP...but I have not confirmed that yet...
Anyways, just to share his work and video links here...
In my opinion, He is making some mistakes...and have no idea how he can reach those numbers.
He is overkilling his setup, the brushes rotation are using a too heavy assembly, too big motor (as Prime Mover), ... just to turn brushes and slip ring assy we do not need that much power!!!
I am using a very small, little 5-18V motor that not even reaches one amp at max RPM's...
In the second video (2018) He is got a different configuration...making even heavier the prime mover...without upgrading his main Generator output source or the Universal Motor...
Again, it is not needed that many brushes like he has on second video...maybe four or six at max, which will divide the Field in four or six poles, instead of two poles with two brushes...and having more fields will reduce the required speed to reach 50-60 cycles...same as in a typical generator.
There are many things that could be done on this setup...like adjusting Brushes Angle, to narrow the Field width from 180º up to 90º ...or more...but all depends on the stator width.
FIRST VIDEO (2016)
SECOND VIDEO (2018)
Cheers
Ufopolitics
―Leonardo da Vinci
Ufopolitics
―Leonardo da Vinci
