Primer field overunity device.
Started by Jimboot, May 20, 2022, 08:58:05 AM
Jimboot
https://www.youtube.com/watch?v=nWESbALZELQ&feature=youtu.be[/font]Quote"This video shows you how to build an over-unity device using PrimerField magnetic arrays. This video also lays some important groundwork for the next video on a fusion-based PrimerField energy source."
This thread is dedicated to examining the mechanism of this device. With help from other members I intend to take measurements to establish the efficiency of this device and see if we can make use of the effect without building a 6M loop
See Tech Planet video here https://youtu.be/DjNg7mxCNYk I'd suggest contacting him and become a donor if you'd like to see a 6M looped version of the device as I think it would work.
3D printing file, CAD specs and other resources here. https://primerfieldfoundation.org/technology-transfer David LaPoint is complete open source and I would encourage you to build based on what I've seen so far on my bench.
Unlike other magnetic gates I've worked with like Howard Johnson devices this one does seem capable of looping.
From my own experiments with 2 bowls.
With one bowl and 360gr of force applied the PM will shoot 1.5m
With two bowls and 360gr of force applied the PM will shoot 1.7M
I hope to replicate his fusion device but that will be another thread. Any ideas or suggestion on test measurements or other applications of the effect would be greatly welcomed. Signal to Noise ratio is important though so I'll be moderating accordingly.
Jimboot
I have a lot of improvements to make on this design. Such as printinting the rollers in tpu. I'll probably reprint and build the bowls with stands too. I'll need an extra set of rollers for support too. The train main need to be a larger diameter so there is less of an arc on the pm as it renters the bowl. Testing soon.
Jimboot
I'm already seeing design flaws before I run it which is good. I hope to learn more from this one before I move on to the next iteration. Any improvement ideas appreciated
lota
Hello
did you use the original files? How big are the magnets? I ordered 10x10mm and will print the shells.
Greeting
Lota
A similar project.
https://www.youtube.com/watch?v=UEc4lw1TWV4
skywatcher
Quote from: lota on May 29, 2022, 04:31:04 AM
Hello
Greeting
Lota
A similar project.
This was also my idea (before watching this video): why not designing a slit into the bowl, so that a rotating disc can be used ?
A rotating disc has the lowest friction, compared to a ring with rollers, and also compared with a tube where the magnets are sliding inside.
With a circular tube there would also be the problem how to start the device.
Of course, if there is a slit in the bowl, the arrangement of the magnets has to be changed slightly.
The question is, if this will have a significant impact on the forces.
Although i'm always saying that magnet motors with only permanent magnets can not work, i feel like i have to try it....   ::)
