The Real No Lenz Generator (opposite Lenz Effect) Watch Video
Started by JackJohn, June 17, 2022, 05:39:53 AM
JackJohn
Sorry for this one I didn't give much detail. 2 phase motor (with a modified coil) as a generator, 24vdc motor as a driver, I didn't take amperage measurements, I only showed that if one phase was short, usually the Lenz effect would cause braking in this speed, this is the opposite of the phenomenon. one phase is shorted, the generator speed increases and it can be seen from the voltage indicator connected to the other phase that the voltage increases.  "Two phase 2 red wires (one phase) yellow and green wires (one phase) the red red wire is connected to the multitester probe. When the yellow and green wires are short-circuited, the speed doesn't decrease due to the Lenz effect, but gets faster"
If you want to know the key to this Device success in eliminating the Lenz effect, then please study in depth  "iron core generator" the concept of Nikola Tesla's . I only mention one about this (Frequency) For the rest please think for yourself
https://dai.ly/x8brc4l
skybiker63
JackJohn
Quote from: skybiker63 on June 18, 2022, 05:10:53 AM
you can compare the power input to the power output...
I purposely didn't compare amperes so that the total input and output power would still remain a little secret, according to the title of the post, that what I show on the video is really real that the Lenz Effect which is supposed to cause braking on the device that I video displays the Lenz Effect which behaves the opposite. you just need to pay attention 1. the driving motor that I use is a DC motor used for a printer machine (if it's close to 1 ampere , the wire will burn/High efficient DC Motor) 2, the copper wire that I used to modify the generator is 0.3mm in size, so please guess for yourself.
JackJohn
Quote from: fer123 on June 18, 2022, 06:40:44 AM
https://youtu.be/bCEnIok2Q0w
https://youtu.be/llH5RgrIb5I
I Hope this one will help you.
Sorry, the two videos don't explain anything about the Lenz Effect, 1 video doesn't show the driving motor, it only shows the power supply cable that doesn't know where it's connected (Less cogging generator) for less cogging generators, you can do 2 things using mumetal core material or keep the magnet away from the core stator . in the second video showing a driver with a very large torque how can you see braking due to the Lenz Effect
