NEW FED PROJECT (QEG LOOK LIKE STATOR)
Started by JackJohn, June 26, 2022, 06:58:01 AM
JackJohn
the free energy device project utilizes a stator with a winding design similar to QEG
still in the process of working, regarding the stator that I use is in the video at the link >>>     https://dai.ly/x8c0cz3
don't forget to turn on subtitles (I Add many languages) so you can easily understand what I'm saying
"Please note that I'm not replicating QEG, the project I'm making is purely my own idea, I'm just using a stator similar to that used in QEG."
The rotor that will be used is a neodymium magnet N52 with a diameter of 30mm and a thickness of 17mm with two poles. rotation speed between 1000~5000Rpm later and Gap Between Magnet and Iron core is 5mm ~ 12mm
JackJohn
Small Update
If you like the project I'm working on please follow my video channel (https://www.dailymotion.com/JackJohn-Device)
JackJohn
JackJohn
ELECTROMAGNETIC GENERATOR PRINCIPLES
Inspire by (energy, frequency and Vibration)
1. Every time there is a change in the induction of the magnetic field in the iron core (stator)/conductor (coreless) it produces electricity
2. The frequency of the generator is determined by the number of poles X speed of change of magnetic poles (RPM) / 120
3. The higher the frequency of the generator is equal to the greater the electricity generated (if compare with same part with low frequency)
Lenz Effect
1. The closer the distance between the rotor magnet and the iron core of the stator, the greater the induction produced but also produces very strong braking (Requires very large power on the driving motor / wastes power)
2. The farther the distance between the rotor magnet and the stator iron core, the lower the braking that occurs due to the Lenz Effect (it takes a small amount of power to overcome Cogging between the iron core and the magnet and weak braking due to the Lenz Effect)
Low Power Drive Motor + High speed + Generator with many poles (Gap is rather wide) + Flywheel + Bridge diode & Capacitor for fast power saving + step down dc to dc + Full sine wave Inverter
is it possible with this technique can get more power out ???
every induction received by the core produces electricity, the faster the induction process occurs (higher frequency) then the density of electrical energy received is also higher and it can be proven by the Battery/Super Capacitor charging technique with the same note that the power used is the same (fast charge and slow charge). charge)
hope it inspires
JackJohn
]UNIK STATOR DESIGN FOR NEGLATE LENZ EFFECT EXPLANATION
https://dai.ly/x8c6ds0
