The breakthrough in Free Energy - a system that cannot be debunked
Started by e2matrix, June 27, 2022, 02:27:39 AM
Tarsier_79
QuoteTen Years ago I discovered the Travis Effect -
And presumptuous of you to name something after yourself that you did not discover... One of my pet hates.
Let us do some hll-billy math with some graph paper on the "cartoon" that is apparently 145% efficient:
By my calculations in this scale:
The power stroke is determined by the effective buoyancy of the container: 20 x 21 units x stroke of 7 units = 2940.
The actual buoyancy is determined by the actual air in the top container: 20 x 8 +16 =186
For reset we need to pull the buoyant load down 22 units: 186 x 22 = 4092.
That gives us an efficiency of (work output/work input x 100) 71.84%
So what am I missing?
memoryman
"Ten Years ago I discovered the Travis Effect -" and still can't explain in ENERGY terms why it is (supposedly) OU.
mrwayne
Quote from: memoryman on June 28, 2022, 03:41:14 PM
Wayne has nothing. There is NOTHING commercially available based on his 'effect'.
p.s. the Travis Effect creates the opportunity for a asymmetrical system... Love it.
mrwayne
Quote from: Tarsier_79 on July 31, 2022, 08:11:07 AM
Yeah - it would have been rude of me to name the discovery after myself - good thing that I did not. Thanks for noticing my non presumptive and non assuming position.
I attached a spread sheet earlier - your doing your buoyancy calcs wrong - as in the Travis Effect - is the effect of reducing volume required to do lift. We use that advantage during work out and then standard buoyancy on the way down.
Take a good look at the spreadsheets - they were done independently, and notice that pressure times surface areas is used.
Watch Markus Nennings two you tube videos - he will explain.
Thanks Wayne
mrwayne
Quote from: memoryman on July 31, 2022, 08:47:51 AM
Oh yes I can - "Less input for standardized work"...Boom - its that easy... Say it over and over until is in your memory.. pun fun..
Thanks Mr Wayne
