JACKJOHN COIL. Test Video
Started by JackJohn, July 25, 2022, 01:19:55 AM
JackJohn
This is my own Ide Coil design, very high efficiency and give 2 power output, from back Emf trapping and from pickup/generator Coil
I have tested the power out of the secondary coil by providing a dc motor load after connecting the diode bridge before, pulling it when the secondary coil is loaded the power requirement for the Driver coil does not increase. I will video it later
This uncompleted test Video.
https://dai.ly/x8cnsju
Tarsier_79
Those panel meters are designed to measure a sine wave, as are most cheap multi-meters. It is not surprising you cannot measure the spikes and back EMF correctly.
Is this a Bedini School Girl Motor?
JackJohn
Quote from: Tarsier_79 on July 25, 2022, 02:03:55 AM
Back Spike is still Back Spike before rectified and stored in the capacitor, but after that (Rectified and store on capacitor) it will become DC And we can meassured it like i do on Video "without diodes and capacitors I will not measure with a digital meter like that because I guarantee it will be damaged(digital V A meter)"
This is not Bedini SSG there's don't have trigger coil just simple 2 coil on it, Driver and pickup Coil and I used mechanical Switch
alextecmen
Greetings, I was happy to see your project, I understand perfectly what you are doing with the coils and their activation, keep testing, I tell you that what you did, I have done it too, and I understand what you are really doing
Congratulations
JackJohn
JOULETHIEF Using soft iron transformer
Let's Check it out
https://dai.ly/x8cshjw
For 2nd test Video using other DC Motor for load
https://dai.ly/x8cshwu
