NEW NEWS
Started by seychelles, July 26, 2022, 02:04:46 PM
seychelles
QUESTION FROM THE LOUD FISHERMAN. CAN TWO IDENTICAL CAPACITORS ONE CHARGE WITH LOW VOLTS HIGH CURRENT AND THE OTHER CHARGE WITH HIGH VOLTS LOW CURRENT BE CONNECTED IN SERIES OR PARALLEL BE OF ANY USEFUL APPLICATIONS?
LONG QUESTION. REASON BEHIND THIS QUESTION IS  ONE CAPACITOR IS CHARGED WITH LETS SAY A STATIC ELECTRICITY GENERATOR AND THE OTHER CHARGE WITH A HOMO POLAR GENERATOR. AND THEN INTERMITTENTLY BOTH CAPS ARE CONNECTED IN PARALLEL TO DO WORK.
stivep
Quote from: seychelles on July 26, 2022, 02:04:46 PM
CAN TWO IDENTICAL CAPACITORS ONE CHARGE WITH LOW VOLTS HIGH CURRENT AND THE OTHER CHARGE WITH HIGH VOLTS LOW CURRENT BE CONNECTED IN SERIES OR PARALLEL //?
-current doesn't exist...without the load
-current is taken by the load.
Please reformulate your question again.
____________________________________________________________
static charge is  just a charge .  - concept of source of charge and look of charging device is not important.
Wesley
onepower
Seychelles
QuoteCAN TWO IDENTICAL CAPACITORS ONE CHARGE WITH LOW VOLTS HIGH CURRENT AND THE OTHER CHARGE WITH HIGH VOLTS LOW CURRENT BE CONNECTED IN SERIES OR PARALLEL BE OF ANY USEFUL APPLICATIONS?
It doesn't matter if the energy is LOW VOLTS HIGH CURRENT or HIGH VOLTS LOW CURRENT as both represent energy.
QuoteLONG QUESTION. REASON BEHIND THIS QUESTION IS  ONE CAPACITOR IS CHARGED WITH LETS SAY A STATIC ELECTRICITY GENERATOR AND THE OTHER CHARGE WITH A HOMO POLAR GENERATOR. AND THEN INTERMITTENTLY BOTH CAPS ARE CONNECTED IN PARALLEL TO DO WORK.
Energy is energy and I have mixed different voltages and currents on many occasions. Static electricity is generally just high voltage and 99% of the visible universe is plasma, https://www.electricuniverse.info/
AC
rakarskiy
Quote from: onepower on July 27, 2022, 12:16:54 AM
AC
Plasma is a structured state of the ether. The structures of the electric field, this is the difference in "conditional pressures" of explosion and implosion. Mono-pressure does not exist, identical pressures in an electric field self-destruct.
seychelles
