Maybe possible idea for duplicating effect of Holcomb and others
Started by citfta, August 19, 2022, 04:00:12 PM
Ufopolitics
Hello All,
Here is how I view the way to make the Circuit Board for Zafer's ESC...
If you find any errors, please, let me know, and I will fix it right away...
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
kolbacict
Quote from: Ufopolitics on September 01, 2022, 12:33:40 PM
Can you please, show which one is the common Y point out of the 4 contacts?
there are three wire in one pin soldering . That's how it's done for me, at least.
If not, the ohmmeter will show.
citfta
Hi UFO,
I have gone over your PCB layout twice and I couldn't find any errors.  Looks great.  Thanks for your efforts.  I will be away from the forum for the next several days.  I may get a chance to check in once in a while.  Keep up the good work everyone.
Carroll
Jimboot
Have a nice break Carroll. Thanks for
The circuit board ufo. My alternator as you realise even with the pairs in series will only be 1ohm. Fox knows what it's out of. I can go and get another but I was wondering if i could have a 3phase rotor inside my 1kw gen stator? Im thinking the coils would need to be overlapping though rather than 3standalone poles.
Ufopolitics
Hello All,
Ok, so here is the same board, just a few adjustments, except components are just "painted" on board to be installed.
In order to show all the circuit lines running under each one.
@Citfta,: Hey, have a nice get away!!
@Jim Boot, I am going to keep playing with the Alternator, I may rewind a new one my way...with thiner wire and more turns...As I found an old motor armature which fits perfectly inside, and I will also be rewinding that one too...to run it with this ESC.
Btw, I wanted to recommend a nice video below, where we can see (one of the ways) to wind a Three Phase Alternator Stator...it is interesting...
I find the field displacement to be pretty "high definition" if  we consider that each pole-phase, change-move every one teeth, and most generators have 36 tooth...So, it is about 1º per shifting phase, say, A,B & C.
WINDING AN ALTERNATOR STATOR (VERY DETAILED)
And so, I already have figured out, how to wind the inner Output Stator...for a higher output.
Have a nice weekend
Ufopolitics
―Leonardo da Vinci
