hi i need help to optimize battery energy
Started by stiplanet, August 30, 2022, 04:35:46 PM
stiplanet
HELLO everyone I am looking for a system that will allow me to optimize the energy of a battery, I am building a small solar lighting lamp, and I wanted to optimize the energy produced by the battery of my system, if anyone has a working solution i will be happy to deal with it, thanks for your help
conradelektro
If you want to optimize the energy in your battery, you have to put a 1 Ohm resistor between your lamp and the battery. This will optimize 1 percent. If you want to optimize 100 percent, you have to use a 100 Ohm resistor.
This is the first law of free energy, the higher the optimization, the more fee it will be.
stiplanet
hi conradelektro thanks for having replied to my message, when you say the higher the optimization, need more fee it will be. does this mean if I want the maximum optimization solution do I have to pay? do you have a solution for maximum optimization
best regards STI
Lunkster
Hi,
Temperature affects the life of a battery.
Different types of batteries have different
rates of degradation at different temperatures.
The best thing is to search this on the internet.
Then you will be able to  come up with different
ways to keep the batteries at the correct temperature range.
The rate of current draw can also affect the battery life.
Again the internet has information about this.
The solar cell angle to the sun also makes a difference.
You may want to want to change the angle a couple of
times during the day if you can in order to put more
electrical energy into the battery in the first place.
The best way to save on battery life is to have the
most efficient devices or processes to conserve
the usage of the devices from the battery.
Best of luck!
Lunkster
alan
You could try to use an electret instead of a battery to see if this is indeed a free energy bemf harvester.
