Desktop Rotoverter?
Started by rakarskiy, September 16, 2022, 05:53:45 AM
rakarskiy
The author has demonstrated this construction. He subsequently deleted his kaknal from YouTube.
The video shows a visual demonstration of the rotation of the engine-generator pair without external power sources. An external power supply is only needed for initial startup.
The author tells in Russian what he is doing, but even without explanation it is clear what he is doing.
The details of the converter are hard to see, but it is logical to hide the battery there (the question is what kind of super-accumulator is it that allows the system to work).
I think we have two motors for different voltages, a high voltage motor as a generator, and the motors are switched through two DС/DС converters. The whole question is in this scheme.
What do you think about this.
https://www.youtube.com/watch?v=7T8Dx2flgzU
r2fpl
How many times do you want to be cheated?
Google: free energy =  around 3 070 000 000
How much of it is real?
Why can't you see it for yourself?
rakarskiy
Probably the transfer of energy over a distance of about 25 cm, such a simple event, with such a transfer effect. If you know this path, you should already be in high demand.
Demonstrate to us, light 12V bulbs at a distance of 25 cm for a total current of 5A, The question will be removed.
PS, the author knew perfectly well what he would be "convicted" for, so he used a glass side and glass table legs made of glass vessels.
partzman
Is it not obvious that the speed of the assembly slows down after he removes the starting battery???
Pm
r2fpl
I don't waste my time on trick shows.
Count how much electricity you need for one motor for a few seconds. Now fit the battery, e.g. Li-po even 3.7V, because the electronics is a power-booster.
At the start, they supply an additional battery up to 100%
Do you need more solutions to this trick?
