audio amplifier as a power generator (instruction)
Started by dxer_87, September 21, 2022, 03:56:14 PM
dxer_87
dxer_87
Left channel may be energized easy way by this circuit invented by me in september 1991.
If you have much load, lower the resistance up to 100 ohm.
dxer_87
corrected extrasync, works with paulos zet solution. the resistor values are minimum.
dxer_87
Paulos Zet solution, strange but true. Connect straight to neutral. Works fine on a 200mm 24 mm thick ferrite core.
dxer_87
Best material for noplis?: sugar pack paper, white wide packing adhesive tape, cut bread packaging foil. Three layers (three times). That's all. (Cut with scissors to be estethic).
