Working Kapanadze Generator Circuit!
Started by worldcup, November 27, 2022, 09:47:02 AM
maxolous
Most builders are stucked, reason being that of interaction and effect. Tesla don't add up even after synchronized arrangements. I believe the system has multiple variations and all be gotten right. There is actually no room for mediocrity in this build, one most know what he is doing.
It just that the system with all the errors that we make is very forgiving otherwise most of us would pack up earlier than expected while trying to build. Most especially when you consider amount invested on procedurement and replacement of burnt components.
I  wish to encourage us to try and investigate faraday's law using Fleming' right hand rule. Simply put use Fleming right hand rule to investigate faraday's law. This might be for you if you have come to a level of this build.
Maxolous
Dog-One
You are most correct in regards to precision.  We are working on the
ragged edges of stability and impedances.  What we would normally
consider a "slight adjustment" turns into an enormous deviation with
this device and puts many off-the-shelf components well outside their
rated specifications.
https://en.wikipedia.org/wiki/Fleming%27s_right-hand_rule
Very interesting Maxolous.  In order to comprehend the phase
relationship, first you have to know which way the current moves.
What is not clear to me is the virtual "motion of the conductor
relative to the magnetic field".  Have to think about that some
more.
maxolous
Quote from: Dog-One on April 21, 2023, 04:02:41 PM
more.
That will be tantamount to the right step in right direction!!!!
Maxolous
Dog-One
Quote from: maxolous on April 21, 2023, 04:42:05 PM
Good to know.
So if I continue to ask the right questions, will the solution be
found standing directly ahead of me?
