Deductions from the Quaternion Form of Maxwell's Electromagnetic Equations
Started by Feb2006, November 29, 2022, 01:34:11 PM
stivep
Quote from: Ufopolitics on December 10, 2022, 02:03:55 PM
All above concept (or sort of "Theory") is TOTALLY thrown out, by a simple, small, Permanent Magnet...which does NOT have any electrical charges, nor electric currents...it is just...A Magnetic Field, NOT generated by anything, but  being there, existing...so, now what?
Besides, on my post It reads very clearly a Magnetic Field accelerates MATTER, not mentioned any "electrical charges"...so, please, do not put words I did not mentioned.
A Particle Accelerator could work with BOTH, Electric and/or Magnetic Fields...NOT only Electric Fields!!
A CRT is the perfect example of a small Particle Accelerator (electrons in this case)...and so, it works with Magnetic Fields or also with Electric Fields.
However, much more common are the Magnetic Fields to deflect the Electron Beam Ray.
it uses electric field for acceleration and magnetic field for positioning – only!!
magnetic field doesn't accelerate and doesn't change the speed of a charged mass particle!!! like e.g. proton.(=mass)
Quote from: Ufopolitics on December 10, 2022, 09:44:47 AM
Magnetic field - field that accelerates matter depending on its magnetic moment.
originally that quote was taken by you from Thomas Minderle "revelation"  :)
answer:
the word its states that you are talking about
accelerated matter by its magnetic field.
and your matter is not specified.
by that my answer was:
For a particular atom, the net magnetic dipole moment
is the vector sum of the magnetic dipole
moments.
So let us take a sample.
A handful of matter has approximately  1026 atoms and ions, each with its magnetic dipole moment If no external magnetic field is present, the magnetic dipoles are randomly oriented—as
many are pointed up as down, as many are pointed east as west, and so on.
Consequently, the net magnetic dipole moment of the sample is zero.so my answer was responding to the exact phrase in question!!!
Overall particles have no magnetic moment in the absence of magnetic field (Ha).
There is a blocking temperature (TB) below which the system behaves as ferromagnetic and above which the system behaves superparamagnetic.
magnetic-moment
__________________________________________________________________
Answer:
QuoteA magnetic field is a vector field in the neighborhood of a magnet, electric current, or changing electric field in which magnetic forces are observable. A magnetic field is produced by moving electric charges and intrinsic magnetic moments of elementary particles ...
So it is specifically said that there is not either/or.  it is the presence of two factors at the same very time:
- moving electric charges
- magnetic moments of elementary particles
https://byjus.com/physics/magnetic-field/
That applies to permanent magnets as well were moving charge is electron in the cloud.
Or by old and outdated planetary Bohr Atom  - electron pair in the orbit.
Wesley
Ufopolitics
Quote from: alan on December 10, 2022, 02:17:33 PM
The magnetic field of a permanent magnet is also created by current, the spin of the electrons of the hard magnetic material constitutes the current.
So, the Magnetic Field of our Planet Earth...was also because someone wrapped the entire globe with wires and ran some huge currents?... ;D
Or Magnetite, which is a naturally magnetized material...was also electrified in ancient times...?
A Permanent Magnet is created by applying currents for a very short time, and only once on its lifetime...and after that process ends... what keeps it magnetized permanently?
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Particle Accelerator: A particle accelerator is a machine that uses electromagnetic fields to propel charged particles to very high speeds and energies, and to contain them in well-defined beams.[1]
A Cathode Ray Tube TV, generates and concentrates electrons by thermionics (e.g: heat resistor Filament at a CRT TV)...and uses two coils to deflect PLUS Accelerate electrons in Horizontal and Vertical axis.
A Rastering of the beam thanks to the high frequency that magnetic field drives beam, generates an image on the phosphoric screen.
A small HV Coil Positive end is used at front of tube to attract (direct) electrons to screen by a metal frame around glass. However, this positive end of the Electric Field is driven at a Constant Voltage, so, no acceleration is done by this electric field.
End of this conversation from my end.
Ufopolitics
―Leonardo da Vinci
alan
Quote from: Ufopolitics on December 10, 2022, 04:52:09 PM
Ufopolitics
I found this
Scientists know that today the Earth's magnetic field is powered by the solidification of the planet's liquid iron core. The cooling and crystallization of the core stirs up the surrounding liquid iron, creating powerful electric currents that generate a magnetic field stretching far out into space. This magnetic field is known as the geodynamo.
https://news.mit.edu/2020/origins-earth-magnetic-field-mystery-0408
alan
Quote from: ramset on December 09, 2022, 02:36:21 PM
PS
Here the group which was many years working with person you "credit " above
And after much disappointment and dead ends ( and unnecessary drama)
Started a new more open group !
https://www.beyondunity.org/
They're going in the right direction. COP > 1 confirmed.
https://www.beyondunity.org/thread/jagau-s-successful-zpm-replication/?p=1
