100 watts output with 60ma input
Started by joellagace, February 03, 2023, 05:28:31 PM
lota
Hello
That's right. These circuits are also used in solar systems. But without the Neo.  It doesn't work that way with a capacitor.
Greeting
Lota
joellagace
Quote from: r2fpl on February 05, 2023, 08:56:06 AM
The battery is chemical. The pulses excite its ions into action. You recover more capacity from a battery that has lost capacity. There are chargers that repair old batteries and operate on high pulse voltages.
Do a test and connect a large capacitor and then check the efficiency that will no longer exist.
Yes your correct.  I mention this in the video, I mention these are crap old donated batteries that I had to pulse charge for over 2 weeks with a Bedini wheel to bring back to life, I mention this and also mention the high voltage pulses to be chemical reaction inside the battery in the video as well and I mention that this action makes the ions swoosh around and I can even hear that "cold" boil Bedini talks about when I put my ear next to the battery. Interesting stuff!
joellagace
Quote from: lota on February 05, 2023, 08:54:07 AM
Hello
my test. The SCR could also be controlled with a PWM.
Greeting
Lota
Cap-Dump Booster Schaltung - YouTube
https://youtu.be/Zf0Zq3HpwF8
I did this a while back for this circuit as well it works. I used a small motor PWM to control the cap dump with a transistor.
I rectify the half cycle output into a high voltage microwave 1UF capacitor. It takes a fraction of a second or less to fully charge this capacitor to 100 volts.
The Tesla Switched, Is a transistor capacitor dump circuit I built. It discharges this capacitor with very low cycle duty sharp timing pulses.
Here is my version of this cap dump method. I was looking for a auto method that would not take as much energy in extra control circuits so I used the neon dump method instead moving forward. I got the whole charge controller pulse circuit to take 60ma only by keeping things as simple as I can. I'm even thinking of replacing that neon with a 110 volts zener diode.
https://youtu.be/XhZRrqV8OMs
endlessoceans
Hey Joel
Nice work.  Have worked with a lot of these type spike systems and you see similar and very interesting results.  Sometime in my experience you witness a polarizing of components and the battery itself and then the results later are not consistent.
Im not doubting what you are showing.  But if you show a schematic and parts then it helps to replicate and troubleshoot/improve
garrypm
Great work Joel,
I remember some dweebing looking guy that wore a navy seal cap that had a youtube video demonstrating
exactly what you are showing.
He didn't give away any info though.
He ran a fan and lights maybe but also had an intellingent battery charger recharging the batery via the inverter.
All I remember is his first name was Peter and surname began with S i think.
Keep at it.
Garry
