100 watts output with 60ma input
Started by joellagace, February 03, 2023, 05:28:31 PM
IMIGHTKNOW
Very interesting indeed. I do know electronics do eat up some power so sometimes I use a small motor spinning a commutator. As long as it doesn't have brush lift the cut off of the power is instantaneous.  Just a suggestion only but will follow for sure.
Thanks.
Dog-One
Had another wild hair idea while I was out moving snow...
Suppose we do this:  A coil of wire always has what?
Two ends.
What if we put switches at each side of this coil.  We turn one side
on and almost instantly turn the other side off.  We do this synchronously
with the most tiny delay between the two control signals such that
even at the speed of light, there is no possible way current could flow
all the way through say 1000 feet of coil wire.  Granted, it will happen
much faster because the wire is coiled up and we have a magnetic
field in play, but still, the control signals can be spaced to nanoseconds;
the repetition rate can be at whatever frequency we can do reliably.
We set our control signals such that they take into account the lag
in our switches--rise/fall & propogation delay.  To create the exact
delay between these signals, we could use a piece of transmission
line (coax).  Just cut it to length and it will guarantee a repeatable
delay time.
I really wonder if using this method, it might be possible to reduce
the input power to nearly zero while still getting quite measurable
back EMF out of the coil.
What say you Joel?  Yes? No?  Maybe so?
joellagace
I think Bedini wanted to do something like this, he called it his transistor coil. Wonder if there are any schematics online?
joellagace
For those who where asking for some kind of schematic diagram, I try to explain the best I can and draw a crude diagram on the spot. Perhaps that will help those who were asking for more details, As you can see from the video. Not much to see. Pulsing a coil is nothing new per say. How ever here is how I do it in details and my rational explained.
https://youtu.be/SZM3DzjiQ8E
Kangsteri
