Wind Turbine Breakthrough!!!
Started by FreeEnergy, February 07, 2023, 10:22:51 PM
stivep
Quote from: FreeEnergy on February 07, 2023, 10:22:51 PM
A must see video:
https://youtu.be/tknzpsaf4qg
the reason it this device was not used  for wind power production  commercially  is that
area of the wind turbine is important for efficient  energy production . That is why blades of   propeller are so big.
Another reason is that  wind randomly blowing , if conflicted by side wind flow  makes less flow into the device
called in that video Darwin "chimney." turbine or whatever.
There is also a reason  why some English man  on  that YouTube  didn't use two   blowers
one in front of the  device blowing on it and  another  one just 180 degrees( or in the straight  horizontally line) but placed  right from opposite side sucking
that air from the first fan and  blowing it blowing in the same direction.
To easier understand it:
The device from video  is called : "Darwin Wind Turbine"
Let's place  two fans  in straight line and both of them are blowing air in one direction.
and place  the "Darwin Wind Turbine" in the middle.
So one  fan will be blowing at "Darwin Wind Turbine" and the other one will be sucking  from  "Darwin Wind Turbine"
This will be simulation of wind blowing in one direction .
Now measure amount of wind  in the  "Darwin Wind Turbine" with the second fan  On and than Off.
and than try to color this  air flow with  some dust so you can see it.
One factor is important -the blower propeller should be  ~6 time larger than the  "Darwin Wind Turbine"
Traditional Turbine redirects itself  into the  changing  wind.
https://www.youtube.com/watch?v=j393Tj0T24E
there is a reason why  such a  "Darwin Wind Turbine" was not used in mining to deliver air to the shaft.
And it is not that air will not flow there, it will,
but from aerodynamic standpoint:
that down push of  air - I would  be surprised is anyone
of you will be at the position  to explain it here  in this group.
Wesley
Dog-One
Keep it simple, just place an order.
