Tommey Reed's BEMF(flyback) Effects On DC And AC Input
Started by TommeyReed, February 13, 2023, 09:07:25 PM
TommeyReed
Hi All,
I wanted to create this test to show bemf
(flyback) effects can happen on both DC and AC power.
This experiment also is great for H-bridge running coils or motors.
I believe Tesla seen the effect when he was working on the Tesla coil and ended up destroying the power plant. This I believe was a surge of higher voltage then the Tesla coil due to flyback effect.
https://www.youtube.com/watch?v=orZfOsNbo6Y
Tom
Dog-One
Attached is a spec sheet.
Why did I give you this?
Because it is a semiconductor device that will switch AC power, extremely
fast and handle pretty high voltages.
Good bye spark gap; hello silicon carbide.
I use the heck out of these Tom; they're terrific devices.  Just do not forget
they are normally closed devices, opposite of a MOSFET.  So make sure you
are already pulsing it when you turn on the juice to it.  They are also a little
weird because you gate them with negative voltage instead of positive.
You apply a negative voltage to turn them off.  Once you get a handle on
how to drive them, they truly are universal switches.
Cheers!
