Magnetic flux motor just patented that creates it's own electricity!
Started by am1ll3r, March 02, 2023, 07:32:40 PM
bistander
Quote from: Ufopolitics on March 05, 2023, 11:57:55 AM
My question is...Is there any other material/component on Earth, that we all could use to replace that very small magnet?
The answer is a radical NOPE, there is NOT!!
A piezo ignition system.
bi
Ufopolitics
Quote from: bistander on March 05, 2023, 01:08:40 PM
bi
You know perfectly well that a piezo ignition system will not work as a simple permanent magnet will.
besides the costs...
A piezo electric system requires a compression force to be applied in order to ignite every time we need the spark to be generated.
A PM will not need but just to simply "pass by the coil"...every certain degrees...a simple rotation which is part of the engine function.
https://en.wikipedia.org/wiki/Piezoelectricity
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
stivep
Quote from: panyuming on March 05, 2023, 11:29:41 AM
Not seesaw.
Do not use the force of the magnet to move the yellow arm away from the stator salient pole at the initial position in Figure 1.
It is necessary to quickly remove the magnet so that there are basically no magnetic field lines on the yellow arm,
and there is no resistance to leave the salient pole.
The magnet should return to the right angle, and the yellow arm should be moved to the next salient pole.
The inertia wheel has a very important role.
I don't understand what would be the benefit from removing cogging?
Wesley
bistander
Quote from: Ufopolitics on March 05, 2023, 01:50:21 PM
Ufopolitics
Ufo,
You asked for a replacement. Piezo is perfectly legitimate. It could work. It's used many places in appliances. For an engine, it would not be as cost effective* or durable as the PM , but certainly doable. If China closed the door on PMs, small engines would find other ignition systems.
It's off topic. I just answered your question.... with a correct answer.
bi
* Cost effective.... For now. But economics change. Maybe tomorrow a piezo chip will be less expensive than a PM and copper coil. Perhaps the piezo system could eliminate the spark plug.
