Building the Vehicle Physicists Called Impossible (feat. Veritasium), OverUnity?
Started by TommeyReed, August 27, 2023, 09:52:06 AM
tinman
Quote from: TommeyReed on August 29, 2023, 05:17:58 AM
Brad,
Really? Come on man (Joe Biden)!
What you are saying is nonsense with the gears theory.
This is another way you claim your geared car would work. Not going to happen Brad!
Yet, you are claiming you can do this with simple gears to move it forward using the same wheels that created friction and even accelerate it forward is just insane comment.
First of all, you might as well say you can move a car down the road without any motor.
Tom
You're not getting it Tom.
The air the prop is pushing against is stationary, so with the wheels and gears experiment, the drive wheels should also be pushing against something stationary. And like the propeller, the wheels on the stationary part of the treadmill, should also be driven by the treadmills belt, which is moving in the opposite direction.
QuoteAs far as the car with the propeller, the treadmill moving the tires alone would cause the car to follow the direction of the treadmill plus the increase load of turning the propeller will increase friction. The propeller needs even greater thrust to over come these factors.
I find it hard to believe that you don't understand how this works.
We have the treadmill belt traveling backwards at lets say 10m/sec, and providing the car with energy, which is translated to the propeller that pushes the car forward at about .2m?sec
Your mistake is looking at the stationary treadmill frame, and not looking at the vehicle in relation to the belt.
But anyway, i look forward to seeing your OU device based around this effect.
TommeyReed
Brad,
Instead of going back and forth and you're not willing to build your car prototype.
I see it different, let me explain what I really see.
If you take a turn table that is control with a speed controller and add the propeller car that moves in the opposite direction. Is it possible to lower the speed of the turn table where the car increases  until the turn table is stop and the car continues to accelerate? '
That is what I see in that video and I must built that next.
"Theories are foolish statements, prototype outcome is facts"
https://www.youtube.com/watch?v=RGUzFs7gT0s
Tom
TommeyReed
Professor Cloxxki(lol)
Instead of talking let just have a build off, just maybe we all can learn something new.
I haven't seen your prototype doing the same as the one on the video, just try to do a geared car going forward, while the tread mill moves in the opposite direction.
My opinion is you're nothing more then hot air with nothing to show.
My idea is to prove or disprove this could be over unity.
The rotating disk and the propeller car will either prove the car accelerate or won't.
4ft diameter turn table would be a good size to work with and a rod attached to the center shaft with a bearing. it could even be a sprag bearing where is will stay still until it accelerate forward.
My theory is the car will continue to accelerate to infinity or break.
Tom
tinman
Quote from: TommeyReed on August 29, 2023, 12:05:57 PM
Tom
Your theory is incorrect.
The vehicle will reach a maximum speed, where the propeller can no longer provide enough thrust to overcome the increasing friction that comes with speed.
See my setup below, where i will not have a propeller pushing against stationary air, but a gear driven wheel pushing against a stationary platform.
Bet i can get mine to go faster than yours Tom  :D
Let the challenge begin--i accept.
I think 4 foot for the rotating platform is a bit big though.
2 foot in diameter would be more than enough.
You set the RPM the platform rotates at, and we will see which car can do the most revolutions in say 2 minutes at a set platform RPM.
Brad
TommeyReed
Brad,
I don't think so, but I plan to do 4' diameter not 2'
One thing that won't happen is the car going forward. the gear ratio is greater then the wheels, this is where the mistake happens all the time.
This is why the thrust worked in the first place, not physically attached to the drive gear system like yours.
Thanks for entering this build, maybe your friend will join too.
Tom
