The most efficient machine ever built
Started by innovation_station, February 10, 2007, 09:04:11 PM
allcanadian
Yikes,that's a lot of questions!
To answer most questions I think it's better to generalize whats happening.
- Total efficiency could be calculated as the efficiency of each machine component(ie compressor/turbine/generator) divided by the number of components.Output minus input=total efficiency(+=OU)
Efficiency is not the big problem however, let's say all components are 100% efficient then what? Your input is equal to your output so you gain nothing!
So in order to get overunity some energy must enter the system and show up on the output, but not effect the input.
Torque is work(Force x Distance) a turning force on your turbine shaft, Power generated on the shaft is a measure of how quickly work can be done, Power = Torque x RPM.
Better yet goto-
http://science.howstuffworks.com/fpte7.htm
it explains everything.
You will see adding weight to your turbine increases the amount of energy stored as energy due to velocity, BUT does not change the input or output --- It is a flywheel nothing more.
The website will explain all your questions, again you need to know the basics first. Research-Research and more Research
innovation_station
well i guess that is the way it sits well i will put this on the back burner for now this machine is a long  way from overunity so i now see
thanks to all who helped
i am on to somthing new it is overunity for sure it is a generator i just came up with it 2 days ago it is half built and guess what i dont need any money to compleate it
it can be made realy cheep i just happined to have all the parts laying around it will be opensource aswell i will start a new topic soon all about it
thanks all agin for your intrest
william filsinger
idnick
innovation_station
Good luck on your next project  :)
Dave
allcanadian
As an inventor I know one thing ,I will fail over and over in order to succeed, I learn from failure. But you cannot fail if you never stop trying to succeed.
CLaNZeR
Quote from: allcanadian on February 28, 2007, 10:11:31 PM
People may call us mad, but if it is in your blood, it is in your blood!!!
Sean.
http://www.overunity.org.uk
