Is this the first selfrunning overunity motor w/o batteries ? Mike?s motor
Started by hartiberlin, February 14, 2007, 08:30:03 PM
war123ren
   hi peterae i am only spaning my coils about 1 inch
   i am only going on what i have learnt through experiance
   washers on rotors are used to balance the rotor
   but making the air gap big is not a good thing
   maybe i am making a mistake but i will test my coils as soon as i can
   i am waiting on the magnets to come from ebay it may take 10 days to arrive
   tommorrow i will get my electronic components from radio spares and build
   the board
   ps i am buying a crow i am not used to useing one  so if any one can help it
   would be great
Peterae
hi Warren
Looks good, good luck, waiting for parts is really annoying, i am waiting on wire and varoius bits of hardware , and a day off which will be monday, i have my electronic components now, i got a nice 33,000 uf 63 volt cap from ebay which arrived yesterday, its big 76 diameter and 115mm height.Also with my explanation of mikes coils, i now see his confusion with the main resistance as i also got confused, he is using the thicker wire 6 Ohm coil as the Generator coil, and the 2 40 Ohm windings for main and trigger.
What do you have planed for your windings.
Peter
Peterae
Warren
The washers i mean are 7cm diameter either side of his armeature.hes not using them to balace the rotor, take a look at the picture.
z_p_e
Quotehe is using the thicker wire 6 Ohm coil as the Generator coil, and the 2 40 Ohm windings for main and trigger.
Guys,
This is not correct. Read what Mike has said about the coils, and look at the scope shots. Start with what was given, anything else is a waste of time.
It is plain to see that the Generator and Trigger coils have nearly the same number of windings or turns. If the Gen coil was 6 Ohms, and the Trig coil 40 Ohms, there is no way these two voltages would be so close as shown in the scope shot.
Darren
McGiver30
are the washers maybe used as a shield from the bearings?...maybe sheild the other poles of magnets to prevent cancellation??
