Is this the first selfrunning overunity motor w/o batteries ? Mike?s motor
Started by hartiberlin, February 14, 2007, 08:30:03 PM
z_p_e
Go for it Warren, and welcome!
Looking forward to seeing your motor.
Darren
dingbat
Welcome, Warren.  I have a lot of experience in the motor manufacturing equipment field.  There are numerous manufacturers of motor winding equipment where I live.  Did you work in the winding equipment field, or actually manufacturing motors?
Quotebut there is another detail that most are missing, and that is that Mike's coil mass is wider than it is high....meaning it is more rectangular than it is square. Everyone seems to be making their coils more or less square.
If you study the Naudin stuff that was posted on gn0sis.com, you can't help but conclude that there are far better strategies for how to shape the coils (my opinion).
I'm sorry, but I just don't think Mike actually knew what he was doing to the degree that everyone seems to think.  Numerous people have replicated the Bedini/Cole window motor and reported various degrees of success, and a concensus that strange things happen with the arrangement.
helmut
Hello All
I would like to learn more from you.
Therfore i like to diskuss about the Theorie,to extrakt energie out of a selfpowering
generator,like we are all searching for.
I think:
If a cylinder with Magnets on the Surface is a Rotor on a Rod,that can spinn on a mount and ist framed with a aircoil. It is a basic Setup.
It is the same,as mike was doing.
Whether there are 2,4,6,10 Magnets on the Rotor dosend matter. As long as the coil generates a field,that makes the Rotor turning with a extern Power Supply.
And if i wind 6 more Coils to the Frame,it does not matter,as long as the operation with a singel coil is able to run the Motor.
So i get the idea,that the outgoing electricity out of the other 2,4,6 Magnets are free of charge.
According to the Number of windings there will be more or less voltage.
And if i imagine,that there is Space for more Frames ,than there is more abilitis to extrakt Electricity out via a Framecoil-arrangement. why not?
Just see  the Rotoverter konstruction--in my Mind it is the same Story.
What do you think about this?
Regards from Duisburg
Helmut
Peterae
Hi Helmut
Very interesting idea, if we prove Mikes system works, we maybe able to increase the net power in the rotor by about 10-15 times by doing that and off course increase generation vy 10 - 15 times.
NerzhDishual
Hi sharp & clever builders/experimenters/theoreticians
I'm very impressed by the high level of some of your posts.
Anyway, I'm slowly going on with my small replication.
L1 and L2 coils are interwoven (bifilar) and square shaped. (wound on a 10 cm * 10 cm cardboard frame).
L1 is 0.250 m/m diam and  84 ohms.
L2 is 0.315 m/m diam and  54 ohms.
L3 is 0.315 m/M diam and  59 ohms.
Too much?
The rotor is made of 6 N/S/NS/... ferrite magnets.
Should you be interested in, more pictures can be seen at :
http://freenrg.info/Window_Motor/
Best
Picture of L3 and Rotor:
Nolite mittere margaritas ante porcos.
