cyberdust
It's on the wrong thread, it should be on the "12 times more energy output than input" with that pendulum and the hammer. Never mind.
NerzhDishual
Hello everybody!
For those who possibly might still be interested in: ;D
I have made some funny new experiments with my window motor.
[With the motor not loaded: I had removed this f' Crouzet relay and the hall probe. It was running pretty fast (sorry no tachometer yet) and was drawing less than 40 miliamps = 36-38 (analog meter).]
First experiment (the motor still not loaded):
I have added a reed relay and put a magnet on the 'inertia wheel'. The relay is 'on' during about 45? (= 1/8th) of the wheel rotation. I have 'choped' the bat with this relay . I mean: the bat is only feeding the circuit during 1/8th of the time.
The motor is still running (but slowler, of course). The analog amp meter needle is moving left and right and shows an average amp comsumption of about 15 mili amp (no capacitor added).
So: you can get a window motor moving with few mili amps and a 'choped feeding'.
Second experiment:
The motor is loaded with a 47 000 micro F cap *and* my SSG2 motor. I wait until the cap voltage is about 12 volts before hand launching the SSG. The two engines are running! The analog amp meter shows about 80 miliamps and the SSG neon bulb is glowing.
Circuit picture:
http://freenrg.info/Window_Motor/Succesfull_WM_SSG_Modifs.jpg
So: no overunity here  :)
But : what about if I could charge-back the bat with the SGG?
Perhaps a step towards OU?
Explanations at:
http://freenrg.info/Window_Motor/Planned_WM_SSG_Modifs.jpg
With this tricky thing:
http://freenrg.info/Window_Motor/JB-RC_Win_Mot_Switch.jpg
Best
PS:
@lancaIV
Meilleurs sentiments but I'm not sure to understand you fully...
Salut NerzDishual,
I,about my own,probably advocati duell, sometimes also not !
We need an impulse and a defined receptor,
the receptor,solid/gaseous/plasma phase,has to be in an " estimulative moment"
to get by the impulse the amplified=concentrated=uni-directional, force !
Ventil-/shielding effect !
Ate breve
              dL
NerzhDishual
Salve LancaIV
Did you see the 1986 Jean-Jacques Annaud French movie "Le Nom de la rose"  (Il nome della rosa - The name of the rose) from the Italian author Umberto Eco?
In this movie one of the monk is speaking a strange language which mix Latin and other Europeen tongues.
When I read your post I can't help thinking of this monk.
Please continue...
Best and kenavo ar c'henta?
