gaby de wilde
Started by gaby de wilde, February 17, 2007, 09:42:54 PM
gaby de wilde
Quote from: Rosphere on February 20, 2007, 09:32:32 PMMy actual experience in playing with this device showed me that this "push-pull" magnetic behavior has an overall "feel" of producing invisible gear teeth.
With the connecting shaft disengaged and both wheels free to move, I...
1. rotated the single magnet on the vertical axis by hand and observed the large wheel with four magnets and
2. rotated the large wheel with four magnets by hand and observed the single magnet on the vertical axis.
In both cases the free wheel spun to match the rotation of the driven wheel, almost as if four invisible, sloppy gear teeth were in play.  The connecting shaft seems redundant.  The connecting shaft has more than four sloppy teeth on it's gears, and they are visible.  These connecting teeth just smooth out the response motion of the free wheel.As can be seen in my video, it slows to a stop when spun in either direction.
The way you can rotate it in both directions is strange. Makes me think your gearing is wrong.
if the south pole is in front of the north and south it can only rotate in one direction.
But looking at the marks on your magnets and the behaviour it look good. But it should only spin in one direction.
QuoteHow is your replication progressing?
This is the best evidence I have so far.
http://gabydewilde.googlepages.com/magnetmotor-it-cant-be
I'm still thinking about it, I've changed the drawing every day so far. lol - The right axle and sprockets is fishy for the weaker/smaller magnets.
QuoteYou might want to use better quality parts than I did.
hehehe, yes but that doesn't go this fast. I think Lego is good physics now.
QuoteI almost forgot to mention.  I made sure that there was some back pressure between the wheels before I slid the connecting shaft gear into place.  This had the effect of moving the wheel several degrees out from top-dead-center, as can be seen in the photos.  It did not, however, continue running.
Some back pressure should be 45 degrees. Maybe there still is hope. lol
QuotePerhaps if you used more magnets around the perimeter, each rotated into the face of the wheel by the same degree in which they are separated upon the face of the wheel making a full 360 for 360.  Perhaps 16 separated by 22.5 degrees?
Good luck with that.   :)
For a closed loop setup you can get rid of 2 magnets, the primary wheel only needs 2 magnets that directly face the secondary.
The photos show that.
I have removed my designs that where wrong and working at some new.  :)
http://gabydewilde.googlepages.com/magnetmotor-drawing
But plz do double check your apparatus.
I'm pretty sure about the single spinning direction.
*edit*
I've attached an image to illustrate how your wheel isn't perfectly pointing at the target. I had the same problem drawing it.
blog  | papers | tech | inventors  | video
gaby de wilde
Quote from: lancaIV on February 20, 2007, 08:33:41 PM
Angus Motor: US4345174
Monroe: US3670189
Bode:US3895245
Rys:FR2112768
and last:
I please to excuse me,for lapsus,not Lee but Chiang:DE19605730
S
  dL
p.s.: when we use a magnetic field viewer and see the neutral pole zone,
       what do we actually now about this sphere/area ?
Ah, there is the promotion material. :D
esp@cenet document view
ELECTRIC MOTOR UTILIZING PERMANENT MAGNETS - Google Patents
GATED PERMANENT MAGNET MOTOR - Google Patents
Electromagnetic engine - Google Patents
Thanks, Great stuff.
WO8203300 says 1 magnet is enough. :-)
<a href="http://v3.espacenet.com/textdoc?DB=EPODOC&amp;IDX=WO8203300&amp;F=0">esp@cenet document view</a><br><a href="http://v3.espacenet.com/textdoc?PRT=yes&amp;DB=EPODOC&amp;IDX=WO2004010567&amp;F=0">esp@cenet document view</a><br><a href="http://www.google.com/patents?vid=USPAT3895245&amp;id=ZekyAAAAEBAJ&amp;dq=%223895245%22&amp;jtp=1">ELECTRIC MOTOR UTILIZING PERMANENT MAGNETS - Google Patents</a><br><a href="http://www.google.com/patents?vid=USPAT3670189&amp;id=2xw4AAAAEBAJ&amp;dq=%223670189%22&amp;jtp=1#PRA3-PA7,M1">GATED PERMANENT MAGNET MOTOR - Google Patents</a><br><a href="http://www.google.com/patents?vid=USPAT4345174&amp;id=nA8yAAAAEBAJ&amp;printsec=abstract&amp;zoom=4&amp;dq=4345174#PPA12,M1">Electromagnetic engine - Google Patents</a>
eugene
Hi Gaby, I'm Thomas from the Steorn forum. We've met there briefly.
Do you know what's up with Steorn? The new Steorn site is the pits, no info there, the log-in window is inactive. Is there any discussion about Steorn on this forum?
BTW I like your present design. I'm going to study it in depth. I used to be a PMM enthusiast, but Steorn turned me off.
xpenzif
You should build it.
PS I can tell you why it won't if you care to know ;)
gyulasun
Quote from: xpenzif on February 28, 2007, 03:46:03 PM
Hi,
I would care to know...
Gyula
