rotoverter for power generation
Started by dan, May 02, 2005, 03:57:50 PM
hartiberlin
The best part seems to be the mechanical Overunity operation,
when the mechanical output power is measured via a prony break torque measurement versus th.
electrical input power.
From the last PDF file I quote here Doug Konzen?s test:
Doug Konzen?s prony Break testing
For the third time I tested the 7.5hp Baldor motor with the series adding wiring which
gives 5.9 ohms resistance to each phase. This time I tore the motor all the way down
first, photographed the internal wiring and labels, and also oiled the bearings just a bit
with some "Kroil" brand hi-tech lubricant.
The phases are wired in Y fashion - and the motor is run in Hector's roto vertor-mode
with a 7UF run cap across lines 2 and 3. At 1650rpm no-load idle, the motor draws
.3Aac @ 120Vac with the 7UF cap.
Any amount of force from the prony brake that exceeds approx 80 ounces on the scale
with the corresponding amps input of approx 2.3Aac will bring the motor to a stop.
In this testing, and the previous too, it has been found that this particular RV'd 3ph
7.5hp Baldor AC motor only likes just a couple narrow "notches" of speed and torque
being squeezed from the shaft by the foot-long Teflon-collar prony brake.
And as before in the two earlier test-runs done this week, it was possible to keep a
consistent force of 54 ounces (3.375LBFT) on the scale, which corresponds to a
simultaneous reading of 1 Aac @ 120Vac input to the motor showing on the meters.
And also a force of 43 ounces (2.687LBFT) and the simultaneous .8 Aac @ 120Vac
input to motor on the meters was another narrow notch-of-power from the shaft to
extract.
So again, it is almost a full HP (746watts) of shaft-power from under 120 watts
electrical input, and still haven?t tried out more UF values to the run-cap in order to
fine-tune it to the load.
RESULTS:
1/20/2007
120VAc grid-power input
7.5HP Baldor motor
.81 power-factor rated showing on label (stock rating)
88% efficiency rating on label (stock rating)
7UF run-cap used in both tests
Test #1:
.8Aac X 120Vac = 96watts input
2.687 LBFT X 1550rpm / 5250 = .793HP X 746 = 591 watts output
Test #2:
1Aac X 120Vac = 120watts input
3.375 LBFT X 1500rpm /5250 = .96HP X 746 = 716watts output
esaruoho
news about lawnmower.. you might be interested in this post from cavetronics, the creator of the lawnmower.
http://groups.yahoo.com/group/EVGRAY/message/15140
do to , some people keep missing with me about the looped mower... it is no longer looped ... your wishes have come true...please leave my people alone now!!!...
Tue May 29, 2007 12:32 am
Cavetronics Labs
Cap discharge "timming" works better then "chips" , because of the cap discharge(the cap moves its "stored energy)  in the system , the cap can store and move the store about , where as the chips can just act as switchs... unless the chip acts as a cap then its not so "waste-full" ....
The same thing applys to coils ,, as coils act like caps to... so what part is going to blow 1st ? the "chips" most likly..
timming is key here " we have X amount of time when the node is at (zero and Max energy) do to the coupling of the gate at a zero node.... so think large switchs = more wider of a gap to colect the energy in the same amount of time...
i made a post about shorting out the sec in a transformer ,,, now lets think about this short as being a charge also...add this with the mower & TPU you have a RV-TPU grass cutting capdischaring rotate motor-generator RotoVerter " like hector said (bang them coils )  i have 300 amp SCRs doing the bangin"  i have about 2ms of BANG(zero node currents) to get and give energy in a BI-WAY of NODES
the rest is All DOWN HILL   like the Back part of the Standing Wave ... USE VSWR and Grid Dip meters and make a DSP unit to compress your 2ms in to 60ms of energy
The key to the Mower...Pulesing magnetic fields travling DOWNhill /\/\/\/\  ( we want this part took off ( \\\\\  ) and we put on this part ( ///// )  to gether they are (\/\/\/\/)+(/\/\/\/)=////\\\\////\\\\
Cavetronics
esaruoho
three new videos from panacea
RotoVerter overunity preview
http://www.youtube.com/watch?v=rhB9rdpnyBI
description: This is a demonstration of Panacea's Roto Verter device (motor / generator coupling version) in an apartment in Brisbane, Australia. By clipping the peaks of the wave form using neon switching or diode plug techniques, it may be possible to extract the resonant / excess power shown on the alternator such as replicated by an open source engineer in France. The neon switch circuits are near completion for this setup. More information including the circuit diagrams are available at http://www.panacea-bocaf.org
energy suppression and rotoverter script
http://video.google.com/videoplay?docid=5757587323690598971
description: This is panacea-bocaf.org's media script on energy suppression and the solutions to addressing the political and economic conditions present.
rotoverter running a drill
http://video.google.com/videoplay?docid=3089731393806776576
description: This is the RV energy saving modification, here you can see a drill turning at 2900 RPM on 240 volts at .5 amps equaling about 120 watts!! the draw also went down to 4.8 amps! http://www.panacea-bocaf.org
ashtweth_nihilisti
http://video.google.com.au/videoplay?docid=3223602109300684830
latest OU circulating current and showing the neon extraction circuit
We are building 4 of them ATM
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
