Rosphere_TPU_01
Started by Rosphere, March 04, 2007, 12:44:40 AM
Rosphere
Quote from: Rosphere on March 06, 2007, 07:44:35 PM
I finally gots me some more caps to feed to my 555 board.  Frequencies shall abound!  :)
Most frequencies.  I spent what was left of myself, after each workday this week, swapping out caps on my 555 board and mapping the frequency limits of each one using my scope.
I have four gaps within the one to five-thousand range.  However, there will be some play in the limits of each range as I left the duty cycle control unchanged while gathering this data.
I may try testing my TPU with the frequencies that I have now before I have the full range covered.
Moab
Hmm, Thats going to keep you buisy for a bit,, Good Luck on your quest Sir! :)
Rosphere
I found a, "signal overlap," for a lack of a better term, at 348~400 kHz.  As I was working my way up the frequency range, I saw these two damped signals at the output coming closer and closer together until, several caps later, I saw a double amplification and an almost pure sine wave output when I probe my final outer-wrap as a bifilar coil.  This is with my three hoop coils hooked in series and my hoops connected as three separate rings.
Also, I have an AM radio inches away and tuned off any station.  I hear a lot of strange things sweeping the frequencies.  Strangest of all is the sometimes dead silence.  It seems my coil is filtering out all of the noise.  I can turn the radio volume up to maximum and hear very little noise.  This is also the case at that amplitude doubling frequency.
See the three probe shots below:
Left probe is at the 555 alone, totally disconnected from the hoop coils. (400 kHz)
Center probe is at the 555 connected across the three series-connected hoop windings. (400 kHz)
Right probe is at the bifilar outer wrap. (348 kHz?)
What happened to the other 52 kHz?
(All shots at 2 VOLTS/DIV, 0.5 ?S.)
MACEDONIA CD
HI  im from macedonia   i like to ask this magnet generator  of Steven Mark  is workig  or not .... I  thing  this is forking  in the simple  oscilations  whith  capacitator  and coil ......   the cap  is 1 time is charcing  and then  is rechargin in the coil  and in this time  hi generatin  in the secondary coil 10 time maybe more  than 10 time more  input  ...   this  is the i say is  ekstra   suplying  thang  input
                   ********** R=12V************
                   *        *** coilwhit stell  ***       *
                   *         p cut        source             *
                   *      ______           12v               *
                               THIS  IS INDUCTIONS   WHIT  COTHING  THE SOURCE
                               THEN   R =12V  IS STOP  WORKING    .  THIS  IN THIS TIME WHEN YOU CUT THE CIRCUIS .. THEN  IN THE COIL  INDUCTION   IS BIGER THEN 12V  IN THE SOURCE    AND AMPS IS BIGER THE 10  OR MORE TIMES THE INPUT   ....................... I THING  THIS IS   THE STORY OF THE  Steve Mark  generator    .....out  is beger than input  and then out is givet to input the lost  energy whit inductions  whit cuting  the source ...( flip flop).....  read this  in the   PHISIKS   IN THE SCOOL BOOKS  ..SORY FOR MY ENGLIS     I LIKE  TO POST  TO EVERBODY  HO IS LIKE THIS ENERGY  TO EXCANGY    TO MY   THINKING    IF YOU LIKE TO SAY  TO MY  POST A EMAIL   ..........cede74sk@yahoo.com.........
Rosphere
Quote from: MACEDONIA  CD on March 10, 2007, 08:13:05 PM
                   *         p cut        source             *
                   *      ______           12v               *
No.  I am using only 9V.  Maybe this is my problem.
Welcome to overunity.com.   ;D
