High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
kokomoj0
Why not just have 3 different threads everyone with their own design and methods?
d3adp00l
Ignoring the off topic posts.
IH, please discuss the pulsing more, I understand each cells unique resonance, etc. What is the aprox. range for more most cells. Square wave, saw, etc, or should it be on-off dc pulses (negative square with no reverse voltage). I would image in order to shake things up, it would be a voltage one way the reverse, if the intention is to pound on the h20 like a jack hammer I would see dc pulses with no reversal.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
Dingus Mungus
Wow... :-[
I did not want to cause this kind of chaos with my observation.
For that I'm sorry to all, but please allow me to explain myself.
I was only trying to point out you're building something new...
I was excited when you started this thread months ago because
of the SGi's production rate I observed. Those bubbles are HUGE!
All I really wanted to do was to find out more about the better
working model you posted in the start of the thread. It had no
complicated cell design, just two 1/4" SS rods in some house tap.
The only thing to learn was the driving circuit and how it worked.
I didn't want to derail your current research with "old hat"...
I'll drop it till you're ready to teach it I guess.
My bad and no hard feelings,
~Dingus
P.S. If you do release more info on the 90v pulsed AC SGi driving circuit you
described months ago, I would be quite happy to learn about it from you.
BasementExperiments
There is sooo much information on this thread, I've printed it and I am still only about 65% through. Almost there, then I'll be able to read this thread on a daily basis.
I think all this information and research deserves some sort of Wiki?
At least so it's easily browsable and all the garbage is cut out. Sorry, I like organized information! :) (im sure we all do!)
Keep it coming, it's not often you find a place on the Net you like to browse on a regular basis.
IronHead
The Series Cell started on Page 4 it's construction because of so much feed back  started on Page 14
Thats correct d3adp00l, On off /no reversal . Things start to really shake right around 40 to 45khz in my cell . Like you might find in a motor controller but where freqs can be dialed.
But your cell with different properties ,like thicker or thiner plates will have a different outcome.
You can do this at any voltage . You have seen the outcome of  many voltage levels.
The point here is these are test that you  do at any voltage level.
You make that decision  to use 12 to 200+ VDC  it does not matter. What you are looking for is a difference from the straight  DC  to pulsed DC.
The center and outer plates is where you will  focus your attention and look for a production difference. You will cause a magnetic field resonance within the cell which will have a gradient through the cell
Huge bubbles is because of high surface tension , not  because of very high production. In this Plate Series  cell the surface tension is broken down very quickly. The gas is release into the air faster  leaving no large surface bubbles like you see it the NS-T cell or Joe Cell. Large bubbles have nothing to do with high  production.
This is what the cell should look like  and sound  like when done properly , Thanks alexleigh. This  is alot of gas pouring off in to the air very quickly.
If this had a high surface tension there would be bubble instantly pouring over the sides of the tub. These bubbles are breaking at the surface.
http://www.overunity.com/index.php?action=dlattach;topic=2057.0;attach=9542
