High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
keithturtle
Right, grumpy, but at what concentration?   0.01 N is enough to start the reaction in  my brute, and 0.1 N really makes it scream.  I use molarity cuz it's easier to quantify and track.
With 100% pure KOH, it takes 56.1 grams / litre for a molar (1 normal) solution, but concentrated KOH is 25% by weight, or 250 grams/litre.  Yer chart sez conc. KOH.  That's at least 20 times stronger that the mix I use. At my anemic strengths, I thought heat would be more an issue.  I've got cells to test this all fer decomposition; just ain't had the time to shake it all out, yet.  Gotta move it on up that cursed priority list, I reckon...
Turtle
Soli Deo Gloria
IronHead
Got a few questions about this. Holes ,picture below
In the news today.
One of the Cell videos on my YouTube  is featured on what looks like a Japanese  XXX site. AHAHAHAHA
rapttor
Quote from: IronHead on June 28, 2007, 01:39:44 PM
wait , did you just call me an ass guru . thats just so wrong
hahahaha
What a $hitty job that is...
On a side note, your recommendation of the mitre somehow knocked me out of my Funk I was in. I stopped yesterday to pickup a fresh bandsaw blade, last night I decided to check all the guide rollers, blade alignment & such, well, everything was waaay off, the table was off ... not true to the blade at all. Once I adjusted / reset everything the way it should be, I was able to cut my slots very easily... it's even easier with acrylic, peel the paper you can see right through it...
I'll finish it up tonight with some pics... So thanks again IronHead... unintentionally you helped me out big time.
-rapttor
Successfully Perpetually Failing at everything I do...
Moab
Hey Ironhead,
Did you ever get that Pwm from Bill? Just wondering if you did and how it worked. Keep it up guys. Lookin great! Moab.
Keep building them! :)
IronHead
I used Chapps PWM  and it is good for low level experiments in the 12 and 24 volt low amp range. I am waiting for the next generation of high amp  mutli outlet boards to test.
If you are using the Chapp board I suggest experiment on half of the cell with it.
The next board should work with up to 3 full cell modules.
