Plasma Electrolysis by IronHead
Started by IronHead, March 08, 2007, 06:31:51 PM
IronHead
the rod will never be hot  like that . The heat transfers to the water in seconds . and then to there air  in seconds.
You have to much tip in the video  go with half of what you have there exposed to the water  you are getting closer.
You will know when she is stable .
hkyle
Those there arks the way it is suppose to be? I'm right on track, time to scale it up? Start pulsin some how?
sorry for the questions.
OK I will do that right now. upload another quick vid in a bit.
It?s easier to be forgiven than it is to get permission....
IronHead
you have to get that arc stable  first.  Right now you are pulsing if you are running a rectifier from 120vac 60hz . With the bridge you are pulsing at 120hz .
BTW  the heat wave you got is a very good sign and at the right level.
One more thing that crosses my mind is that you are very close to the surface of the water . lets just see how this goes. I would really like to see a higher water level above the arc but
lets just see what happens here.
hkyle
OK new vid is being uploaded right now. There is about 3/16 of rod open to the water in this vid..Yes it is a full wave bridge, I would like to be in the 20k range but your right let me get this stable first the wory about pulsing at that level another time.
I must say that those there changes in the rod made one hell of a difference...
Thanks man...
I will do another vid with the rod lower if I can. Not much more screen there.
EDIT...
OK here it is
http://www.youtube.com/watch?v=eKkLc4bc7Gs
Not too bad 53 watts of juice...
Quote from: IronHead on August 04, 2007, 12:55:27 AM
One more thing that crosses my mind is that you are very close to the surface of the water . lets just see how this goes. I would really like to see a higher water level above the arc butlets just see what happens here.
IronHead
How far away is the screen from the rod? how far around the rod does the screen go ?
