Plasma Electrolysis by IronHead
Started by IronHead, March 08, 2007, 06:31:51 PM
Robb077
Hkyle:
I think you're making headaches with the design.  Why not get one going well with one screen with the rod down the center as Ironhead suggested...and get one going well before trying to make two.
Moab was right, the video sounded like eggs frying :D
hkyle
Have you noticed wat I have done latley? What headaches? Seems pretty simple to me. I do have one that is running well. The problem with the current design is the amount on water in the cell, need more. Why not step it up a bit. It's not like this costs me a whole lota cash..This took me 1 hour last night to build. It is a easy build and anyone can do it if it has positive results. Thats why I'm doing it. I could have built 2 more units each having there own screen and seperate water inlet and outlet but thats more material and more time. This seems better for a build, to me anyway. If this does not work like I had planned then I will do multiple units in series with each other. As the water gets pumped from the first to the last cell the water will get hotter.
What video?
Quote from: Robb077 on August 09, 2007, 12:20:19 PM
Hkyle:
It?s easier to be forgiven than it is to get permission....
Robb077
Hkyle:
I was referring to the video you posted on youtube, the 40 watt one....nice job.
The best idea is to have two screens vertical and run the rod down the center so it has equal space on each side.  Hey, you've done more on this than I have, so maybe I shouldn't comment, LOL.
hkyle
OK guys new vid again for ya...This one here is with the new CFR. This guy is pulling a little more amps than what I wanted but still..Boils 1 gallon of water in 5 min. It is pulling 2.5 amps at 118v. not bad but still have to remember that when the water is circulating it will pull more amps all the time because the water is being cooled down over and over.
Also with this design the rods come down from the top into the middle of the screen, this is WAY WAY WAY better than coming in from the bottom...This way you can actually see the plasma being pushed away from the rod, and also rides up along the side. This actually makes more plasma and generates alot more heat...from what I noticed anyway.
Here is the link.
http://www.youtube.com/watch?v=q7YofGZVw7g
Comments welcome.
keithturtle
@hkyle- cain't see the vid tonite- on the dino line.
So, what you've discovered, as I grasp it, is there ain't a symmetrical relationship betwixt the rod and screen?
If'n that be the case, mebbe my egg whisk idea may have some hope, once I get polarity straight.
I wanna do some testing to determine the nature of the arcing, cuz there ain't no screen, field or other positive infulence nowhere near that lower arcin' SS bolt in the pic.
That is, other than the 3 VDC potential I measured in the water...
Working with HHO fer a few- back to the plasma next week.
Keep at it!
Turtle
Soli Deo Gloria
