Plasma Electrolysis by IronHead
Started by IronHead, March 08, 2007, 06:31:51 PM
Moab
Est cost of build
1 Grundfus pump.                 60.00
1 fiberglass H-W, Rv tank           25.00 (Salvage yard)
1 4''X18" stainless nippel 188wall  32.00
1 limit switch                            10.00
1 DC Pwm. 50amp 1 Khz 600 Khz          Built it so i dontknow Maybe 50.00?
Misc 1'' stainless fittings about    45.00
312. 2''X4'' screen 4 Pak            16.00
1 45 amp Bridge. Out of the junk box 10.00 ?
Misc copper for plumbing            60.00 maybe
Tungston I used 1/4''                 22.00 10 pak
Misc magnetic chokes.Again i built them Maybe 5.00?
Heat exchanger Ebay                  35.00 use a radiator for forced air heat
52 gallon H-W tank  You dont need it if you dont do the floor heat
4  3/4''flow controll valves          32.00
Gas volume controll                    7.00
1/4'' nylon hose for venting gas   5.00
So you can see there is a good bit to the build. if your going to do it, gather up all the stuff youre going to need. I'm sure i missed some things. Its cheaper than building a conventional boiler. But then again I didnt do it beacuse its cheap. what i learned from the build is priceless. If you go in to it whith that attitude you cant loose.  ;)
Since youre not doing the radient floor heat your build will be a little different, But not much. happy build planing. 8)  Moab.
IronHead
Thanks Moab for taking this thread, I just don't have the time.
Again thank you.
IronHead
Moab
You're welcome Buddy.. Just dont let me make any stupid mistakes. :o. LOL
Koko. On the pulsed vrs rectifyied.. From what i see the rec seems to spark up better. So what i do is let it run on the DC 120hz then after every thing is heated up. I switch to the PWM. This i find works well and also seems to make the screen and rod last longer. The freq +-+-+-Flipped and is between 12 and 27 Khz. It is always different after a change out, like i said. So you need to tune it every time. So they both work. but after she heats up the SQ wave is the way to go for the 14 day run. I'm still learning as i go. So dont think me an expert. :) Just a builder.
IronHead
The more you work with this cell the more it will teach you.  In the long run it will be simplified as it will show you in time.
Robb077
Moab:
Great detail....thanks for the post!
