new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
Frederic2k1
Stefan,
why did Richard say, that he hasn't got a motor in his setup ? I can see at least one in this picture:
And when you compare the red wire going to the motor, it is the same wire which is used in the setup with the red case behind the spin wheel at my post with the circuit diagram, marked with "motor input +" and "motor -".
Take a look at the video, where he connected a drill, a lamp and the jigsaw, to start his setup he only switch the on/off button and the wheel does immediately start to spin up. I don't belive that you can have such a smooth run-up with only one little coil.
I think the setup is somethink like a cheap generator without lenz law effect, just overunity...
The picture you have shown is where Richard said,
that it is a modified alternator.
Read again all and his last postings.
This was an earlier device with the modded alternator.
Also he wrote in his last postings,
that the white bigger disc is
just a flywheel to keep the RPM constant
and you also see him gining the small
white wheel a push,so it acceleretes at the start.
As it seems he is now only using
some solid state coil with some
kind of solid state magnetic particle wraps or
other solid state magnet parts near it,
he seems not to need anymore any moving magnet
fields...
Regards, Stefan.
Frederic2k1
Ok, but I agree particularly.
In the newest video (where he give the white wheel a push, I confess to that) you can also see the "motor" with the red wires. At 0:13 - 0:19 at the right site of the screen.
kind regards
hendrik
powercat
When logic and proportion Have fallen
Go ask Alice When she's ten feet tall
Frederic2k1
ok Stefan,
you are right, there is really no motor inside. I had overlooked it sry :)
kind regards hendrik
